Question about Electrical Supplies
I start de generator ahd the light of L.H.propect is on and emergenci stop and off de generator.
  • 355 Answers
Check your oil level. many generators have a low oil level light and will shut off to protect the engine
Posted on Jun 09, 2010
I took de oil filter out i connected direct tube i start de it didnt start
Check de-compression lever. Motor will not start if de-compression lever is operated. The lever stops the valves from closing. If lever is operated then there will be no compression when motor is pulled over with starter cord or electric starter operated.
Check fuel cut off at injector pump is not operated. This is how motor is normally stopped.
There must be no air in the fuel line, fuel filter, injector jump or injector. Undo the fuel line at the injector and pull starter or operate electric starter. Fuel should spit out. If not, crank some more until fuel comes through.
if there is fuel in the tank, filter not blocked and injector pump working then if not fuel at injector then maybe injector pump faulty.
If fuel at injector line then remove injector, crank motor and look for spray of fuel.
If if you have checked for spray of fuel and motor compression then motor should start.
Mar 15, 2015 | Kipor Kde 5000ta Diesel Portable Generator
Have generator showing emergency stop code and will not start.
there are too emergency stop sensors on generators
one is over load
the other is low oil level in the sump (Low oil pressure)
That sensor is known to trigger and activate the emergency stop so check it out after you check the oil level in the sump
Feb 26, 2015 | Kohler 20resa 20kw Home Emergency Backup...
Sensor de aceite de un onan cummins rv QG 4000 generator 4000w
If it runs while start button is pressed but stops when you let go?
Check the rotor bruhes, slip rings are clean on the rotor. If you want to get deeper check and ohm the resisitance of the rotor, and stator both for continuity and ground shorts. Check plugs and wiring on control board. Failing that replace control board
Nov 18, 2012 | Onan Cummins RV QG 4000 Generator, 4000W,...
Keeps stopping
which type of generator had an Olympian GP18 which would start and stop immediately, we were suspecting that the emergency switch had been pressed and left on but it so happened that the starter relay was the one loose.
Regards
George
Sep 01, 2012 | Cars & Trucks
How to reset FAIL TO START(over crank)?
Over crank is just that too much cranking with a filed to start. Plese check gas pressure and for voltage on the fuel shut off solenoid
Aug 16, 2012 | Kohler 12 kW Emergency Power System -...
My generac 15kw generator went off on overcrank now the relay just clicks then stops then clicks agin, i have 13 volts at the battery
It could be either your start capacitor or the contactor-relay. Or you could try cleaning the contacts of the relay with an emery board to see if there is a change.
Sep 07, 2011 | Kohler 12 kW Emergency Power System -...
Generator won't start. Screen showing OC.
OC means OVERCRANK safety circuit stopped the auto start-up so you wouldn't burn up the starter. There is a reason the generator didn't start. Low battery, not enough fuel pressure, clogged air filter, bad starter... You just have to eliminate as many as you can visually. Rebooting the generator should clear the OC condition and you can try to start it manually.
Oct 11, 2010 | Kohler 12 kW Emergency Power System -...
Kohler Confident 7 model 7CCKM22 generator
sounds like a relay should be latching one it has started
Feb 04, 2010 | Kohler 12 kW Emergency Power System -...
Generac generator remote start
si tiene transfer automatico solo poner un swicht en hilo 1N para cortar senal de entrada al generador del utility power que sensa la presencia de voltage en caso de falta arranca el generador en forma de prueba
Dec 19, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Feb 19, 2009 | Kipor Electrical Supplies
Electrical Supplies Logo
556 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
