Question about Char-Broil Quickset Traditional 463761006 Grill
Charbroil Thermos Gas grill is only 10 months old and has been used 10 times. Went to attach gas tank and plastic screw on part of regulator that holds it onto the tank shattered. This grill has been always stored inside out of the sun and elements. Never saw one do that before. Can I get a new piece for it or do I have to buy a whole new regulator?
    New Friend:
  • 4 Answers
Plastic piece is not replaceable, time for a new regulator...
Posted on Oct 07, 2017
    Top Expert:
  • Char-Broil Master
  • 40,323 Answers
Fixya does not sell Char-Broil parts.
Posted on Oct 05, 2017
SOURCE: thermos grill-to-go.
found thermos website which I was unable to do previously. Thank you.
Posted on Jan 31, 2009
  • 10865 Answers
SOURCE: need some parts
Hello. Most hardware stores will have replacement parts which work on all grills. good luck .
Posted on Feb 04, 2009
  • 388 Answers
SOURCE: I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Posted on Sep 07, 2009
SOURCE: Ducane Firelight Campstove/Grill Regulator/Hose Assembly
I have a a never-used Ducane Firelight Campstove I will sell for $50 . I believe I paid $189 or more for it. However, I do not know in which area you are located
Posted on Mar 29, 2010
Need gas regulators for thermos grill chr696047031200
Hi Dale.
The inner connection to the gas plumbing is pretty much the same across lots of grills. If you're looking for a screw-on to the propane tank, regulator/valve, and hose, then this will likely work
Robot Check Hmm, it's coming up as Robot Check on the link name for me, but clicks through to Amazon. you can also go to Amazon and search for 'Sturgis Propane LP Gas Replacement 21" Hose & Regulator 3/8" Swivel End'
Hoping that helps!
Dec 03, 2015 | Thermos Grilling
Plastic knob on regulator is cracked causing gas leak where it attaches to LP tank. Needs replacement. Can I get a regulator/hose?
Hi kimandjimm...
You can use any generic hose and regulator assembly for your grill.
You can buy it online at:
You can buy them at HomeDepot,Lowes,Ace Hardware,etc. Look in the grill section.
Please take time to rate me
Sep 07, 2011 | Char-Broil Patio Caddie 4654870 (LP) Grill
I need the metal part where the gas bottle connects too..
I can only assume your talking about the regulator and screw on connection. These can be bought at most large hardware stores including sears to fit most if not all grills. They basically all use the same type of regulator and gas supply lines. Fot this protable grill you may have to get online at
Jul 13, 2011 | Thermos Grill2Go Fire+Ice
Name & source for quick-connect LP gas tank adapter piece?
Did you find what you needed? I have the same problem.
Jul 22, 2010 | Thermos Stainless Steel Gas Grill
New Charbroil gas regulator leaks
The connector on the grill side that connects to tank may be bad. Call manufacturer and they should send you a new hose and regulator for free since it is a new grill. If grill does the same then replace tank.
Apr 25, 2010 | Char-Broil CharBroil Master Flame Gas...
Regulator doesn't allow gas to flow to grill . Grill cannot heat hot enough to grill steaks. Gas flows too slowly.
Shut off the gas at the tank and disconnect everything.
Unscrew the plastic cap on the regulator. Inside is a flat screw top that has a single slot or an X-shaped slot. This is the pressure adjustment. It controls the diaphragm that regulates gas flow.
Note where it's set. Use a Sharpie to mark the adjuster on its edge (place a dot there), and make a corresponding mark on the threads next to it.
Next, use a large screwdriver or a coin to spin the adjuster counterclockwise three or four times. Pay attention to the number of turns. Now, screw it back in (clockwise) the exact same number of turns, stopping at the index mark you made.
Next, turn the adjuster two turns clockwise, followed by two turns counterclockwise. The idea is to end up where it was originally set. This action unsticks the regulator's valve seat. Done.
Put the cap back on, hook it all up, open the tank valve, and make fire.
Jun 23, 2009 | Thermos Stainless Steel Gas Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Shelf for over fire of portable gas grill
go to this link and fill lin the boxes, then tell the charbroil customer service dept. exactly what u need.
Aug 14, 2008 | Thermos Grill2Go Fire+Ice
Thermos Gas Grill
This is caused by a bad regulator. This is the silver device that usually attaches directly to your tank. Most hardware stores carry these regulators you will need the numbers off it to match up a new regulator for size.
Jun 21, 2008 | Thermos Stainless Steel Gas Grill
Char-Broil Quickset Traditional 463761006 Grill Logo
179 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
