Question about Canon PowerShot S2 IS Digital Camera
Display I have a s2is and you can't see anything on the display or through the eye piece. any fixes?
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on May 30, 2010
  • 10,594 Answers
It is known problem of ccd imager failure in S2IS Canon camera and ccd imager chip will be replaced to get live view to take fresh picture.
Local camera repair shop will repair camera by replacing ccd imager chip because camera will take apart and soldering work is also involve so its not likely novice fix.
Thanks.
Display Problem
Fix it before it goes bang. It will 85% be the steam boiler seals leaking, remove the lid and have a look when operating, keep your fingers out, use your eyes.
Jan 22, 2014 | KitchenAid Coffee Makers & Espresso...
Recently lost gun in water for a moment, Now scope gets fogged inside. Is there anything I can do to stop it? It a fairly new scope.
Your scope may not be hurt if water has not caused any rust yet. Things you will need, (1) hair drier, (2) Vaseline, (3) large clear plastic bag, (4) gas from a paint ball gun canister or similar type of inert gas you can use. Remove the eye piece, and shake as much water out as you can. Use the hair drier and heat the tube up, not too hot but warm, to dry the inside as good as you can, keep after it, shaking it and heating it. Once you feel all the water and moister are gone. Put a good amount of vaseline on the threads of the eye piece. The put the scope, the eye piece in the plastic bag. Use the paint ball gas and inflate the plastic bag, tie off the bag leaving room so you can screw the eye piece back on the main tube. Leave the scope in the bag for a few minutes before you do screw the eye piece on letting the gas fully get in the tube. The gas will give a bit of positive pressure inside the tube, Will displace any other air that will have moister in it. Keep the inside from fogging back up. The vaseline will help seal the gas inside. Hope this Helps Fix Ya up.
Apr 25, 2011 | Bushnell Sportsman Rifle Scope 3-9X 40...
I have a pair of Plastimo military binoculars which have been fine up to now, but suddenly, despite being able to focus using the two eye piece controls, I cannot get anything other than a double image, no...
Hello - I never had Plastimo before but I have had a similar problem with double vision on a very similar looking pair of binoculars.
The eye piece movement just re-aligns eye focus differences , a double image usually means one of the lenses has moved inside the main tube. (usually from a knock/fall etc)
Can you rotate either one of the tubes ? On my pair I had to rotate anti-clockwide and found a prism inside that had slipped after a fall -
Close one eye and try to gauge which side is the best side -- Ray
Feb 05, 2011 | Plastimo Optics
I have a nikon d 40 and was wondering if the display screen can be used to preview the shot instead of using the eye piece .
The Nikon D40 is not equipped with the Live View feature which allows the user to use the camera's LCD to preview the shot. You can only use the viewfinder eye piece.
Dec 26, 2010 | Nikon F75 35mm SLR Camera
Why can't I see anything? I have removed the lens cover (the whole thing). When I take the eye piece out adn look through the focusing mechanism I can see light and very small images. When I put the eye...
Put the eyepiece with the largest number written on it into the scope and try again. Contact Bushnell directly for repairs:
http://www.opticsplanet.net/bushnell-warranty.html
Sep 21, 2010 | Bushnell NorthStar 78-8846 (675 x 114mm)...
Taking pictures without using the eye piece.
The XS does not have the feature of using the display screen for composition/preview of images like the smaller compact digital cameras. You will have to use the eyepiece like a standard SLR.
Feb 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My Camera will no longer turn on. I've swapped out recharged batteries but nothing seems to work. This a refurbished camera that canon swapped out for a s2is that was having problems with no display on lcd...
There may be something more serious wrong with the camera, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, wipe both ends of the batteries with the cloth, and reinsert them into the camera. This clears the problem about 90% of the time - I hope it works for you.
Sep 09, 2009 | Canon PowerShot S3 IS Digital Camera
VEIWFINDER IS BLURRY CANNOT SE OBJECTS CLEARLY
At the bottom of the eye piece there is a little slider than you can move up and down to adjust the focus. That should fix your problem if not then you are not looking into the eye piece close enough make sure your eye is pressed up against the little rubber pad and then adjust the focus.
Apr 23, 2009 | Cameras
Can not see anything through eye piece (i am new to this hobby)
During the day time-- put the lowest magnification eyepiece in the telescope... the one with the biggest number on the barrel; practice focusing on a distant object.
Dec 26, 2008 | Meade Optics
Hi there, I have a Canon Powershot S3IS and just lately when you try to turn it on it comes up with a message that says E24. I have looked through the manual and cannot find anything resembling this...
You have 2 choices here, one is send the camera into Canon for exchange or replace the Camera, this would be based on cost. You can't fix it as no parts are available from the manufacturer to the public.
Apr 05, 2017 | Canon G7 G9 S3is S5is S2is
Canon PowerShot S2 IS Digital Camera Logo
261 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
