Question about NEC Electra Professional ETW-16DC-2
How to program a line to ring keysets
Customer has an older NEC Electra Pro (KSU is E5F-C-10) with four lines connected. How to do we program L4 to ring all the keysets? Where can we download installation manual?
  • 2 more comments
  • boud64 Apr 17, 2008
    How do I get into programming on an Electra pro 1 and make 2 extensions ring when phone calls come in.
    right now only ext 10 rings and i need ext 14, 1 to ring as well.
    I am very familiar with Elite, IPk etc but the prg steps must be different.
    Pls help, Jamie b
  • Myrtle01 Oct 31, 2008
    I have a similar problem. An ETW16DC-2. Three of the phones are working to call out, but you cant hear the phone ring. Please help!
  • di_shaw22 Dec 03, 2008
    I also have the ETW-16DC. Only the main line rings, but the others do not. Can't figure out how to get the other ringers to work.
  • Anonymous Mar 26, 2014
    I was able to set my NEC Aspire phone programmable keys to outside lines. But when a call is placed to those lines the phone I just programmed does not ring. The lines flash though. How can I get it to ring?
  • 3 Answers
I HAVE THE MANUAL
hisrev@yahoo.com
Posted on May 29, 2008
Not sure if I understand your question correctly, but I think I just learned how to do that on an electra professional. Memory block 4-1-1 lets you go through each of the internal extensions, and you can set each extension to ring when a call comes in from any/some/all of the outside lines.
to reach memory block 4-1-1, I used a multi line terminal connected to ports 1. Press fnc => hold => # => 0 => * => line key 4. Use the fcn(?) key to cycle through the internal ports, the line key buttons to map each of the 4 lines (presumably line keys 1 through 4 on your system).
As to where to get a manual, I am not sure, I have 3 thick binders... good luck
Posted on Apr 09, 2008
I HAVE ONE PHONE THAT RINGS AND THATS IT HOW DO I MAKE THEM ALL RING WHEN A CALL COME IN
Posted on Jul 31, 2008
  • 3 Answers
I have a similar problem. I use a NEC Electra 2 system. I 'm trying to set the number of rings for our phones. The type of phones are NEC ETW -16DC-2. Would you help?
Posted on Apr 25, 2008
HOW COULD I RESET THE NEC SL100 PBX SYSTEM?
Download manual from: https://www.manualslib.com/manual/832824/Nec-Sl1000.html?page=531
System Reset on Page No. 2-509 of the manual:
Dial 1 + press HOLD (Press Hold key only to cancel)
Jul 04, 2013 | NEC PABX SL1000
NEC Electra Elite IPK B64-U20 KSU
I have a PRI and am asking the same question. I do know that you do have to go into programming to set this up. You also have to have a COIB card installed for this to work for standard Direct Inward Dial lines.
Apr 18, 2013 | NEC Electra Professional ETW-16DC-2
HOW CAN I ANSWER THE PHONE WITHOUT PRESSING ANY BUTTON?
It has to do with a program called ringing line preference. Program # 4-11. Check out www.wedophones.com/Manuals/NEC/Electra%20Elite%20IPK%20Programming%20Manual%20-%20Document%20R%204.pdf
If you happen to have an Electra Elite 48, 192 or IPK this manual can show you how to program that feature. Don't take it lightly though, you can jeopardize your system if you do not know what you are doing.
Sep 08, 2009 | NEC DTH-8D-1 Corded Phone
Programming
yes enter program mode and change MB 4-01 for your port number. Assignment of ringing per phone.
Jun 02, 2009 | NEC ETW 16DC-1 Corded Phone
Office NEC phone to be used at Home
This phone is a proprietory digital phone that only works with a KSU. You would need an IPK or Elite phone system to make it work. You would also need to program it. This is a business office system and that phone will not work unless it is plugged into the system.
Feb 05, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Professional Level I Upgrade
The NEC Electra Professional Level 1 has a maximum CO line capacity of 8 in any configuration. If you need more outside phone lines, you will need a different system. If you need to limit cost as much as possible, the cheapest avenue would be to upgrade to a used Electra Professional Level II. That way you can still use the same telephone instruments, but ALL cabinet hardware would be different. Also, you can only get to 8 outside lines if you have software level 3.00 or higher by using the COI-C(2A)-10 card. To verify which software version you have, I think you press FNC(3) on sta. 10 ( or the first station in the system). If that doesn't work, let me know, and we can access the system program to verify version number.
Dec 29, 2008 | NEC Electra Professional ETW-16DC-2
LINE 3 RINGS ON ONE PHONE- AND DOES NOT RING ON THE OTHER 3...
You actually need to set the ringing in program mode. Your NEC vendor should be able to help.
Check out LDTSNJ.com for low price service rates.
May 19, 2008 | NEC Electra Elite 32D-1 Corded Phone
NEC Electra Professional ETW-16DC-2 Logo
551 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
