Question about Panasonic EY7542LN2L 14.4 Volt Li-ion Multi Drill & Driver Kit with Light
Moderrate resistance stops the drill from driving and to scream
The drill motor seems to work fine. When on the drill setting on the clutch any moderate or greater resistance to driving a fastener or drilling causes it to stop driving and start what sounds like a loud fast bad grinding sound. Are there gears that transition from the motor to the chuck that can strip? Is this easy to fix or the end of my drill?
Thanks!
  • 553 Answers
The grinding you're hearing is the normal sound for the clutch. There's a ring with numbers on it the higer the setting the more torque it'll take for the clutch to slip. Many of the newer drill & drivers have a drill setting at the high end of the clutch settings others have a separate drill & driver setting. This site will give you most everything you need.
http://www2.panasonic.com/consumer-electronics/support/Building-Products/Cordless-Tools/Drill-Drivers/model.EY7542LN2L
Posted on May 30, 2010
Why does my drill chuck seem to disconnect from the motor?
from pos 32 gear and the drive shaft on the armature can be worm out. or something was broken else.
Detail
Jul 23, 2014 | Dewalt DW505K 1/2" Hammer Drill
Torque limiter quick to engage Why?
Usually it is a worn clutch that will cause this.
May 26, 2014 | Drills
How do cars with clutches work?
Clutches are useful in devices that have two rotating shafts. In these devices, one of the shafts is typically driven by a motor or pulley, and the other shaft drives another device. In a drill, for instance, one shaft is driven by a motor and the other drives a drill chuck. The clutch connects the two shafts so that they can either be locked together and spin at the same speed, or be decoupled and spin at different speeds.Clutches are useful in devices that have two rotating shafts. In these devices, one of the shafts is typically driven by a motor or pulley, and the other shaft drives another device. In a drill, for instance, one shaft is driven by a motor and the other drives a drill chuck. The clutch connects the two shafts so that they can either be locked together and spin at the same speed, or be decoupled and spin at different speeds.
-------------greebid.com
Nov 07, 2013 | Cars & Trucks
Motor works and spins but as soon as the drill touches the wall drill stops but motor keeps going.
Check the speed switch on top - sometimes it doesn't fully seat in the 1 or 2 position. Switch it to the opposite setting, run it, then switch back, until it seats properly. Also check the clutch control ring for the same issue.
Jul 21, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
I HAVE A DEWALT 991 3/8 DRILL DRIVER. THE MOTOR TURNS AND SOUNDS FINE--THE CHUCK CAN BE HELD WITH LITTLE PRESSURE AND A CLICKING SOUNDS COMES FROM IT. DO YOU THINK IT COULD BE THE CLUTCH ASSEMBLY? JIM
Ensure the clutch collar is turned to where the little drill bit Icon is top dead center of the drill. If this is so, and your gear selector switch is not between gears, you will need a clutch. If this is a 991 Type 1, you may be able to get away with just an output gear, which rides against the ball bearings of the clutch.
392755-00 Output Gear part #. Generally when it is that bad, you will have to remove the clutch from the transmission without taking off the chuck, because the needed resistance for that operation is simply not available.
Nov 11, 2010 | Dewalt 18 Volt Compact Drill Kit
How is a driver different from a drill? What
Hello, W/D here.
A very good question......A drill holds a bit and rotates it at a given speed. This speed can be variable, allowing the speed of the drill bit to be better matched to the material being drilled. The output from the drill motor goes directly to the chuck, and the power is directly applied to the drill bit. Some drills can generate a tremendous amount of direct torque, due to the nature of their gearing. Most of the better drills have planetary gears in them.
A driver rotates like a drill, but is designed to apply torque to a driving bit, and cause a fastener to be placed by the driver. The main difference between a drill and a driver is that a driver has an adjustable clutch, allowing the amount of torque being applied to a fitting to be preset. A good example of this would be for driving wood screws. You would dial in the torque setting that you want the driver to quit driving the screw. You don't want to drive the screw to China, you want to drive it flush. A maximum torque setting "locks" the clutch, and the fitting will be driven as far as it can go (This is about as close to being called a drill as a driver will ever get). A clutch setting midway might be just right for driving the same fitting into oak, and a setting at less than that might be just right for pine. The torque clutch effectively sets a kick out torque for the driver. When the torque applied matches the torque set on the driver, the clutch "slips", and no further driving action can occur.
Most modern battery powered drills incorporate a torque clutch between the motor and the chuck so that the tool can be operated as a drill (with the torque setting at "max") or as a driver (with the torque setting at less than max) some electric tools are configured as both, but usually they are different. For the money, a good battery powered drill/driver with a clutch offers more versatility, in my opinion.
Best regards, --W/D--
Aug 19, 2009 | Dewalt Home Fencing
Seems like the clutch has gone in the drill. Can this be replaced? When I squeeze the trigger the motor turn and the drill spins but if I put any pressure on the chuck it stops spinning even though the...
Try rotating the driver adjustment to make sure it is on a definate number, not in between or put it all the way to the drill position. A little 3-in-one oil does wonders as dirt and dust will keep it from rotating and engaging easly. If this does not work and the clutch is stripped, cost of rebuilding it is not worth it, usually 70% to 80% of a new one and other parts on it will wear out and you will be fixing it again. Good Luck
Jul 03, 2009 | Porter Cable Cable 14.4 Volt Cordless...
When in drill mode the tork still kicks in on my dewalt
clutch is bad. can be repaired but ive always had a pro do it. bit spendy
Apr 22, 2009 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
The motor turns but the clutch will not engage
Take the drill out of the hammer drill setting when in reverse.  Using the drill setting with the speed on 1 will give the power to free the bit.  If the clutch will not engage, GENTLY but firmly switch between forward and reverse.  This should work just fine.   I hope this solution brings you success!  Best Regards,  Michael Mittelsdorf
Dec 26, 2008 | Drills
Panasonic EY7542LN2L 14.4 Volt Li-ion Multi Drill & Driver Kit with Light Logo
156 people viewed this question
Top Panasonic Drills Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Richard Warren
Richard Warren
Are you a Panasonic Drill Expert? Answer questions, earn points and help others
