Question about Samsung SW62ASP Top Load Washer
Remove the inner drum from 13kg Samsung top loader
How to remove the inner drum from 13kg Samsung top loader
illistated drawing will help, WA13G7Q1
please?
SOURCE: I am trying to remove the inner drum
The top panel?? Remove the screws at the bottom front. Pull the front panel out from the bottom while releasing the clips on top. remove the screws in the corners under the front of the top panel and swing the top up.3bceb93.jpg
Posted on Jan 06, 2008
  • 142 Answers
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
Posted on Sep 14, 2009
  • 1937 Answers
SOURCE: need to remove the inner drum to try to patch a
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following illustrated description of how to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=c1fdfdd9f5c92acf030438f5108905f5
You don't need a special spanner wrench to remove the spanner nut. I've found that a 10: pipe wrench hooked over one of the tabs on the spanner nut and using a hammer to tap the handle works well.
Don't use a hammer directly on the drive block. Use a short piece of wood under the drive block and tap it with a hammer to remove the block.
When replacing the block make sure to align the tabs on the drive tube with the slots in the drive block before tightening the spanner nut.
Posted on Oct 31, 2009
dmftrucker
  • 1922 Answers
SOURCE: I want to know how to remove the inner drum on my
you will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Posted on Nov 19, 2009
  • 84 Answers
SOURCE: whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Posted on Dec 28, 2009
My samsung top loader of 13kg shows code dE
Many Samsung top loader washers are recalled due to a severe unbalance issue that causes the top of the washer to become dislodged and fly off. Enter exploding Samsung washers in your search engine. Since your machine may be recalled, you may have a free service call coming your way anyway!
Nov 10, 2016 | Samsung Washing Machines
How can i remove drum over for samsung toploader washing machine. Clicking noise when drum is turning. Model nr wa13g7q1
bra braces or something between wash drum and heater element .unit.? remove the drum or
Set the machine on its side ?
Dec 16, 2015 | Samsung Washing Machines
My Samsung 13Kg Top Loader WA13G7Q1 continuously drains out the water when the drum is being filled , what could be the problem
Either your in house drain pipe is too low or your drain pipe is down into the drain too far and this causes a siphon effect. Pull drain line up out a little at a time until it stops draining while filling. Good Luck!
Jul 28, 2015 | Samsung Washing Machines
Where to clean filters on Samsung 13kg top loader?
Sounds like you need to have your machine looked at by a professional. You should not be finding rubber pieces in the machine.
May 08, 2014 | Washing Machines
Samsung washing machine 13kg.top loader model wa13g7q1, machine intake water run for a while then changed operation into drain and drained water for a while then display IE error . what will be the...
The problem is the pressure sensor is either clogged or defective or a broken wire. To check if you know how to take apart look for sensor with small clear hose attached. Put some water into tub and disconnect little hose and blow into it you should hear like blowing into milk glass with straw. If no then you have a clog if yes you have bad sensor or wiring. If not able to find this call 1800 Samsung for there products.
Mar 17, 2014 | Samsung Washing Machines
How to remove a samsung 8kg top loader drum to pressure clean and remove black rubber like build up
No need to remove the drum. You can buy cleaning agents for the washing machine at the local supermarket. You have to actually run the machine in cleaner solution and you have to do this every 3 months at least.
Jan 16, 2014 | Samsung SW62ASP Top Load Washer
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
I want to know how to remove the inner drum on my Samsung top loader to enable me to clean the outer drum.
Nov 18, 2009 | Admiral AW22 Top Load Washer
Samsung SW62ASP Top Load Washer Logo
950 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
