Question about Miele T9800 Electric Dryer
Can't seem to get heat My Miele dryer is 3 years old
  • 177 Answers
if your condenser is blocked the airflow is restricted and can cause the thermostat at the rear of the unit behind the cover to create an open circuit. you would need to remove the rear cover and check with an electrical meter to see if the thermostat has resistance. it looks like a small round disc with a wire going to each side of it. you can order a replacement thermostat from Miele but remember to also clen your condenser before running it again.
Hope this helps.
Posted on May 31, 2010
  • Jimmy Miele Aug 04, 2011
    Our Miele 9800 dryer didn't heat and we called the service technician from Miele. Our thermal elements needed to be reset. Pull the plug before you do this. Take off the small back panel with a phillips screwdriver. Reset the the three thermal elements. Put the cover back on, plug in and try again. A Miele is like owning a Mercedes Benz or a BMW. This is a high technology German product that needs attention at times.
Drum not turning. There is heat. Opened machine found broken belt. Drum will not turn by hand. What would it cost to fix?
in the package of the new belt, the belt for the dryer the instructions are right on or in the package, if not normally you take the front and possibly the top of the dryer 1st.... off slide the belt over the drum, and the insert it through the tensioner and then unto the motor. you have to make sure the belt has tension on it this will show it will be able to move the drum.... you can download maintenance manual form here
http://www.slideshare.net/avermapub/miele-gas-dryer-t9820-service-manual
price depends where you purchase it.. $ 20 to $ 45
Sep 25, 2014 | Miele T9800 Electric Dryer
Miele tumble dryer
Maybe time to replace it. How can it be too much detergent? That would have the effect of lubricating the seals!
Mar 04, 2014 | Dryers
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
Dryer Miele T9800- 3 years old Lately the air doesn't get hot, it will be warm and it will take over 90 minutes to dry clothes that before were done in 15 minutes.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 13, 2010 | Miele T9800 Electric Dryer
We have a miele dryer T 234 C and a recent has
Hi most likely seals on heat exchanger (condenser unit).
Lock heat exchanger in place.the should no movement at all.if movement you will require a rear seal for heat exchanger.Where heat exchanger seals in condenser box clean with scourer. check bottom of door seal for debris.
Mar 23, 2010 | Miele Novotronic T220 Electric Dryer
Diagram of wiring on Miele dryer
Hello cpopp101,
Please follow the link and goto page 30 for the electrical requirements. The manual is for the T8012 but all the dryers are the same for electrical. Goto page 30. There is usually a seperate fuse box for these (Depending on how old the dryer is) in which you may want to contact Miele to see if you have
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T8012C_8013C_us.pdf
Good luck
Sep 17, 2009 | Miele Novotronic T1515A Electric Dryer
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Not drying
I had the same problem with my dryer.
MAKE SURE THAT POWER IS OFF AND PLUG IS UNPLAGED AT WALL
On the back of the dryer there is a white metal cover in the centre with two philips screws. Once removed you will see metal box which has elements like a toaster built inside it.
You will see two sensors sticking out of top of metal box. The left one is the sensor for safety cut out in event of the dryer sensor on the right stopping working and letting the dryer overheat.
If you disconnect the left sensor 2 crimps and put multimeter on the left sensor two pins and if the meter beeps on continuety the sensor is ok. but if no beep the sensor is bad.
If sensor bad you can tempary bypass the sensor by joining the two cables together and try running dryer on a program and if heats up you know that you need to get new sensor.
WARNING! IF YOU LEAVE THE LEFT SAFETY SENSOR BYPASSED IF THE RIGHT HAND SIDE SENSOR MALFUNCTIONS THE TEMPERATURE WILL RISE AND CAUSE SERIOUS DAMAGE OR FIRE. THE PURPOSE OF THE RIGHT HAND SENSOR IS WHEN THE DRYER HEATS UP TO HEAT IT CUTS OUT AND WHEN DROPS DOWN IT HEATS UP AGAIN SAME AS AN OVEN.
You can maybe buy sensor from a meile dealer or RS COMPONENTS have the same sensor for £3.35 each.
NOTE: I ACCEPT NO RESPONSIBILY FOR DAMAGE OR INJURY IN MY ADVICE FOR REPAIR OF DRYER.
Jul 02, 2008 | Dryers
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Miele T9800 Electric Dryer Logo
389 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
