Question about Quinny Baby Gear
My quinny rear wheel keeps losing air, ive replaced inner tube but it keeps going flat
    Champion:
  • Quinny Expert
  • 223 Answers
Hi it sounds like you have something stuck in th tyre itself that is punturing the new inner tube, take them out & feel inside the tyre if there is anything sharp there remove it. Then you can repair the tubes.
Posted on Aug 07, 2010
Tyres keep going flat repaired many times replaced inner tubes still got problem
I'd check the inside the rims, there must be something rubbing against the tube. There is a product bike shops sell that is basically a solid foam inner tube. Check out your local bike shop.
Dec 09, 2010 | Quinny Baby Gear
How can I fix a bugaboo rear wheel
Need to know what's wrong with the wheel? If it needs a new inner tube it's a 12.5 x 175-2.25 your local bike shop can get you one. This inner tube many strollers examples are the Quinny Buzz 3 and 4 (rear), Quinny Speedi SX (rear), Quinny Freestyle, Maxi Cosi Mura 3 and 4 (rear), Bugaboo, Phil and Teds E-type, X-Adventure, Joolz Bloom, Joolz ZZZ One, Joolz Day, Teutonia, Easywalker, Cossatto Mobi (rear), Baby Jogger City Classic Single (front and rear) and Double (rear) and many more.
Nov 26, 2010 | Bugaboo Frog Stroller
I have the quinny buzz and have a problem with one of the rear wheels. It appears to have 5 holes in it (around the inner part that attaches to the plastic centre part, they are very small holes and I had...
hi this is a very easy fix have you searched the web for quinny buzz inner tubes? ebat has loads if you are in the uk
or it is a 12 inch bent valve inner tube my advice is when you have repaired these put in tyre slime
this will help any future punctures by repairing them immediatley and you wont even know
very good stuff had it in mine and never had to pump them up good for any inflatable tyres with an
inner tube
Nov 16, 2010 | Quinny Buzz Three Wheel Stroller
Replacement rear wheel of quinny buzz
You can buy tyres off ebay at about £9 each. inner tubes are very cheap on there as well. Check out local bike shop as they might be cheaper.
Jul 26, 2010 | Quinny Buzz Three Wheel Stroller
One of my tires on my quinny buzz keeps going flat how can this be fixed? Is there a tube inside the tires?
Yes there is an inner tube which sounds as if it has a puncture. I bought replacement inner tubes off e bay for mine when the same happened to mine. You can then either take the tyre off yourself and replace the tube (bit fiddly unless you have a suitable tool like a strong screwdriver for releasing the tyre) or try taking it to your local bicycle shop who could no doubt remove and refit the tyre for you for a small fee.
Jul 13, 2010 | Quinny Buzz 3 Sulphur Jogger
An you get hard rear wheels for the quinny buzz 3
No sorry but you can get new inner tubes very cheaply off ebay & something called gludge(i think thats what it is called) anyway all bike shops sell it so does ebay, you can buy it to put inside tyre so you won't get a punture or a spray which you put inside inner tube it seals it right away if you get a puncture . it is easy to do I did it myself.
Jan 17, 2010 | Quinny Buzz Jogger
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
One of my Quinny Buzz Tires are flat. It is
You need to either have a new inner tube put in it or you can try adding a flat repair gel in the tube to fix the leak. You can get what they call "Green Slime" their are other brands also available under different names but this is most common. It can be purchased at Walmart, Home Depot, Ace Hardware and Auto Parts Stores. This is easy to pump into the tube valve stem without removing the tube or wheel and should fix any holes or leaks on it. Then just pump it up and you should be ready to go.
Hopes this was helpful, DutchTexan
Oct 15, 2009 | Quinny Buzz Jogger
Where can i buy a spare back wheel or inner tube for a Quinny Buzz 2005?
You can buy a 10 inch inner tube from most cycle shops. This does just fine.
Apr 11, 2009 | Quinny Buzz Three Wheel Stroller
Buzz rear wheels wont inflate anymore
I just ordered new tyres and inner tubes from my local pram shop. 8.50 for tyres each and 5.50 for inner tubes. Pram centre in Glasgow. Also ordered a new front wheel for 29.
Mar 11, 2009 | Quinny Buzz Three Wheel Stroller
Baby Gear Logo
192 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
