Question about Kenmore Vacuums
I have a kenmore vacuum and can not get a new belt any where for it. I only bought this a year ago from Kmart. The Model #21637000800 MFG code 108B Belt # UB-11
SOURCE: eureka whirlwinde litespeed vacuum - model 5841
very simple under all three screws in the front (two on sides and one in back) once open--you can take off that panel...take brush out...take old belt out...put new belt on..around brush..place both inside...and make sure belt is around that little pole thing towards the back close panel, replace screws
Posted on Jul 24, 2008
VacuumRepair
  • 438 Answers
SOURCE: Belt broken a a Kenmore
Greetings from GoVacuum.com,
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled.
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Posted on Oct 01, 2008
  • 6 Answers
SOURCE: Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Posted on Oct 26, 2008
SOURCE: Kenmore Model 116 PowerMate Jr stopped working
If the roller brush is not spinning freely once you remove it from the Power Mate Jr., then I have discovered the solution! There are end caps at each end of the roller brush. They seem to be permanently attached, but they are not. There is an axle inside the roller that is permanently attached to one of the caps. Take two pairs of pliers, and grab each end cap with a pair of pliers. Then pull hard to take them off. Once they are off, you will find that there is a big glob of hair wrapped around the axle inside. Remove the hair. Then reassemble the brush by putting the end caps back on. Make sure, when you put the caps back, that they are aligned so that they will fit back into the slots on the Power Mate Jr. You have to push hard to get the caps back on, maybe tapping one of them with pliers.
Posted on Mar 28, 2009
  • 148 Answers
SOURCE: i need a belt for a kenmore 721 vacuum please
Should be able to get one at local Sears store , or try sears.com
Posted on Feb 13, 2010
Vacuum seems to have lost some suction and is harder to push on carpet
Start by installing a new belt. Belts lose elasticity fairly quickly. And should be replaced at least twice per year. Belts lose elasticity even if the vacuum has never been used. It's possible for a brand new vacuum to actually have been assembled a year or two ago which means it may end a new belt before it was ever used for the first time,
Feb 24, 2015 | Vacuums
How do I get to the belt on a Kenmore vacuum cleaner, belt on a kenmore elegance canister,
Take it to you local vac shop for service. If the belt is broken there is another problem. Those belts are not supposed to break. The machine has a circuit breaker. If the breaker didn't function properly and caused the belt to break, you will likely just break the new belt.
Feb 18, 2015 | Kenmore Vacuums
Hoover Elite 300 belt replacement?
Take the broken belt to a vacuum cleaner repair shop to match it up to a replacement.
May 27, 2013 | Vacuums
I own a Kenmore vacuum cleaner model # 116. 56550990C. I have lost the instructions to replace the belt in the Power Mate. The Power Mate beater just stopped working and I need instructions on how to...
If unit beater has stopped working it is either the motor, the power connection to beater or the belt that powers the roller. Which is it?
See if you can download the manual from the mfg or google for it.
Sep 05, 2017 | Kenmore 25614 / 25615 Progressive Bagged...
I have a Eureka 4800 series the Boss upright with a bag and Hepa filter. I love it! I was just vacuuming with the hose part and all was well and then suddenly the lower brush came on and a "burning" smell...
I had the same problem. Take out the old belt if possible. Remove the 4 screws inside the filter and the 3 on the front of that housing. pull out the foam around the motor. carefully pull out the suction tube that is press fit against the motor. then you can pull the motor out. place it on its side, shaft side up and grab your hammer. tap down the metal sleeve that has been rubbing against the plastic housing. reinstall everything including a new belt and you should be good to go.
Apr 18, 2010 | Eureka 4874 Bagged Upright Vacuum
Lever & belt placement in Kenmore Progressive upright vacuum
You are correct. The belt is supposed to go around the peg that is connected to the lever so that when it is on the Floor /Tools setting the belt is not driven by the drive shaft.
Dec 05, 2009 | Kenmore Vacuums
Kenmore vacuum - no suction, brush wont turn
sounds like the vacuum is clogged and putting too much stain on the agitator, so I would clean out the entire passage way for the vacuum and replace the agitator belt, you must clean out all the hoses it is clogged somewhere
Jan 29, 2009 | Kenmore Vacuums
Kenmore vacuum- no suction, brush wont turn
Sounds to me like you have a plugged vacuum. Check all the way through.
Jan 29, 2009 | Kenmore 22812 Bagged Canister Vacuum
I have had my Dirt Devil for just less than a year. I bought it in September, '07. Last week I was using it and it suddenly stopped running. I can see no reason why. I need to find a nearby repair...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=846706
Generic problem for all Vacuums
I have had my Dirt
Posted by mamavelda6 on July 28, 2008
I have had my Dirt Devil for just less than a year. I bought it in September, '07. Last week I was using it and it suddenly stopped running. I can see no reason why. I need to find a nearby repair station. I cannot afford to buy another one. I bought it at Kmart; it was on sale for $49.97.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I can see your problem but if it is anything more than a new belt or brushroll, it would be cheaper to buy as new one because the price of the part plus the labor fee will be more than the price of a new vacuum or you can buy a good used one from your local vacuum cleaner dealer in your area. If it is the motor then definitely buy a new vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 28, 2008 | Vacuums
Vacuums Logo
149 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
