Question about Eljer Toilet Onepiece Canterbury 081162047
Keeps clogging - Eljer Toilet Onepiece Canterbury 081162047
  • 349 Answers
Have you check the toilet for proper water level in tank. Level will be near mark on overflow tube or within 5/8" from top or it adjust float if not to get it there.
Next is the fill line 1/4" poly line connected to fill valve to overflow tube to allow proper amount of water in bowl.
Port's under the rim are clear on not clogged you can use a nail or paper clip to push through thes to clean out. You can't see them they are under the rim of the bowl.
If something fell in bowl and got flushed it could be hanging up in the trap in the bowl. If you have some rubber gloves check out drain in bowl before trying to use something to push it further in the drain.
If nothing found maybe try a 6 ft auger you can get these fairly cheap and they are handy to have around.
Posted on Jun 11, 2010
Car runs fine, then stops running. Why does it take about 4 or 5 tries to restart and keeps shutting off?
Catalytic converter/s clogged up. Or fuel filter clogged up. Remove the pre cat O2 sensor, if it keeps running, replace the cat/s.
Nov 27, 2015 | Cars & Trucks
Thermostat
Bad water pump, low on water..thermostat bad, cooling fan or fan relay switch broke,clogged radiator ..Catalytic converter clogged .....These are the first things to check...
Aug 10, 2013 | 1997 Mercury Cougar XR7
Where can i buy a new sp500g and how do i keep debris from clogging it?
You will need a tech to replace it, but to keep it from becoming clogged, thoroughly rinse your dishes before loading them into the dishwasher.
Apr 17, 2012 | Dishwashers
02 mercury sable egr pressure feedback sensor keeps melting on the smaller vacuum side. And keeps blowing out smaller hose. Engine is running ok at idle but will not accelerate past 20 mph. What would...
Most likely it is the catalytic converter one the firewall side clogged. the part that melts is the exhaust feedback side and it backs up the hot air once the converter is clogged. I had same problem on 03 escape. Also resist putting straight pipe on downstream converter because it catches any loose carbon from going into the muffler. If the muffler is clogged it will do the same.
Aug 12, 2011 | Mercury Sable Cars & Trucks
The dishwasher keeps clogging.
Pre-wash majority of crumbs off plates and heavy grease off pots first.
Jul 07, 2009 | Dishwashers
Chute for bagger keeps getting clogged
John Deere LA 125. Chute keeps clogging up with grass.
Apr 22, 2009 | Garden
My washer is clogged
pump is clogged and/or needs replaced
Apr 10, 2009 | Amana NAV5800A Top Load Washer
Bissell Lift-Off Revolution keeps clogging
Sounds like it is partially clogged. That yellow thing you are talking about, twist it and it should come out, clean or replace the filters, then re-install it. Check the hose and make sure there isn't a clog in it and clean any other filter. One problem with this bagless is the filters will clog up fast and need to be cleaned on a regular basis. Another place a clog happens is in the inlet by the brush roll.
Nov 07, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Eljer Toilet  Onepiece  Canterbury  081162047 Logo
130 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
