Question about Dell DVD-rom DVD Drive
My computer does not acknowledge my cd rom, will not play any cd that is put in, does not even show up under my computer. how do i fix this?
  • 428 Answers
Might be a device failure. Have you checked the cables (by changing)?
Does it show up in the BIOS settings? Check it. If it does boot to the OS. Right click on My Computer icon and Select Manage. Go to device manager and check whether the device is having any problem (It should be listed their and must not have red X or yellow ! mark. If one of these are there that means the dives is having a problem with its hardware or firmware driver). If its there and no errors shown what you have to do is: Go to disk management and check properties. It will show the stats. (If its not shown their either a device failure or the drive is hidden). Finally if nothing works: Start -> Run Type this in Eventvwr.msc Click on System. Check for CD Rom errors. It should be listed their if the device having a conflict. It might be a device level or api level failure. Please post the error list next time after running Event Viewer.
The last thing is that if you (or any malware) created a registry entry or a group policy edit to remove the drive from being displayed you have to re adjust the policy. Scan the machine. Try to do the following.
Start -> Run Type in this gpedit.msc Expand User Configurations Expand Administrative Templates Expand Window Components Click on Windows Explorer Check whether these settings are enabled. "Hide these specified drives in My Computer" Double click on the setting. If enabled disable it If not Enable it for a drive (lets say A: drive) Click Apply and OK Then Disable it again. Click Apply and OK Follow and apply the same steps for this setting as well. "Prevent access to drives in My Computer".
Any of those steps will help you to solve the issue. If not contact further.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
Posted on May 30, 2010
I have a Systemax Venture Microsoft Windows XP Pro Version 2002 Service Pack 3. The system will not longer play dvd's or cd's and cannot burn cd's as well. I'm not sure if something has...
Well the fact that when you put in a cd it does not see it indicates that either the CD Drive is not being detected or the drive has gone faulty and needs replacing.
First Look in the bios of the computer to see if it is seen the drives section. If it is there then look in windows under control panel , system, device manager. Now look under DVD/CD Roms drives (this may differ slightly in XP) to see if in there with no error against it. If not and not in the bios either then the drive has failed. If however it shows in DVD/CD Roms with no error then try a different make of cd/DVD. If this works then the Bios of the drive will need updating. This info is on the manufacturers website. Good luck.
May 10, 2011 | Systemax Venture PC Desktop
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Jan 30, 2011 | Lite On XJ-HD166S Internal DVD Drive
Why does my lenovo insist on my having a cd rom when i have a dvd writer installed? how do I fix it so that computer recoognizes it?
I have the same situation. My computer has a
DVD-RW/CD-RW installed yet when it is empty, the computer simply recognizes it as a CD drive. However, it will automatically recognize any DVD I place in the drive. Even a blank DVD-R. So it's not really a problem for me.
Also, if you type in DEVICE MANAGER in your windows search area, it will show you all your computer's hardware and peripherals. I have Windows Vista 64 bit and in device manager it does recognize it as an ATAPI DVD under "DVD/CD-ROM DRIVES".
I haven't seen a DVD burner yet that won't play or write cd's; maybe this is standard.
I wouldn't worry about it as long as it performs the functions (play/burn DVD's?)
Mar 14, 2010 | Lenovo 3000 J Series 2.10G Xpp PC Desktop
CD-ROM drive doesn't acknowledge DVD-ROM, what's wrong?
CD-ROMs dont play dvd becuase they are not designed to read dvd.
If a dvd drive for your model is not available, you can buy an external usb dvd drive.
That should solve your problem
Dec 28, 2009 | Dell Dimension E521 PC Desktop
Use to burn cd's on my acer/pentium ,, but now no hardware shown
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Jul 15, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer aspire 5520 cd rom drive is missing
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 05, 2009 | Acer (99.B0311.002) Internal 50x CD-ROM...
Computer will no longer read. play or even acknowledge dvds or cd
Try this:
How to fix the CD player
1. Go to System/Library/Caches and trash the folder com.apple.kernelcaches
2. Go back to System/Library and trash the file Extensions.kextcache
3. Restart.
If that doesn't work, try trashing this file:
~Home/Library/Preferences/CD Info.cidb
That is the way its done
Dec 17, 2008 | Computers & Internet
CD R/W DVD R/W
Check if your drive is receiving any power. Open the case and check the wiring. Mind you dont remove any other cables
itJSN
Aug 12, 2008 | E-Machines emachines (emachinees) CD-ROM...
Advent 7113 - dvd/cd
hi
you need to check if the drive is Cd rom or a DVD rom if you try to play a DVD on a Cd rom it wont play, IF you are doing everything right then
try this
Go to my computer i mean right click on my computer and click on properties and then hardward tab >> and device manger>> and under DVD and cd right click on it and uninstall it and restart the system
Jun 08, 2008 | Computers & Internet
Cd-rom
Check it from Device manager;
Right Click my computer. Go to properties.Hardware tab; Device manager; See under device manager ! any yello sign; ETC;
If you could not find any alternate Best Solution is try replacing CD DVD Rom
Regards
Rafique
Mar 17, 2008 | HP (PR017UA) PC Notebook
Computers & Internet Logo
375 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
