Question about Sony KP-46WT510 46" Rear Projection HDTV
Fixing the convergence ic's
Do I need to call a repairman or can this be done by myself?
  • Sony Master
  • 8,617 Answers
Do it yourself, its an easy repair and if you go to the following link they have the replacement ICs and they include free step by step instructions on how to do the repair, and they offer free on-line instant messaging with one of thier techs will youre doing the repair, They even have service manuals. Heres the link
http://servicemanuals.vstore.ca/ If you dont know your IC numbers just click on the contact link on the lower left side of thier homepage and send them an email with your model number and they will get back to you quickly with the proper ICs that your model uses.
Posted on Apr 08, 2008
Mitsubishi vs60607 is showing double picture
you have a convergence issue. The convergence ics need to be replaced. These are soldered in place and should only be done by a professional repairman
Dec 31, 2013 | Televison & Video
Hitachi 46f500 46 in problem double picture end two collor
This is symptom of convergence output chips failure in rear projection tv, replacement of convergence output chips will fix the problem.
Chips/ IC replacement requires soldering work in circuit board, if you are not familiar with electronics stuff fixing an soldering work, call local tv repairman to help you.
Thanks.
Oct 26, 2010 | Hitachi 46F500 46" Rear Projection...
We just recently bought it used and had it moved. Now there is a constant shadow and on words its even worse. I can't get into the program to align it manualy. Can I find a way to do it myself or do I need...
Most likely a repairman - but review the info below to determine
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 28, 2009 | Philips 55PP9401 55" Rear Projection...
We have a problem with the ghosts. double people and colors are all over the place. went to convergence and tried to enter to go to auto or even manual but only got lines of different colors can we fix...
Need a repairman - unless you've done soldering and electronic component replacement b4.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
Oct 24, 2009 | JVC AV-65WP74 Rear Projection Television
Distorted Color and geometry of Picture
Sounds like a convergence IC problem, you will need to replace them'
Heres a quide
see the before and after pictures to verify your problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 15, 2008 | Televison & Video
Sony KP-61XBR200 Convergence problem
STK392-020 ICs are the convergence ICs for your model, you may also want to check the 3.5 amp pico fuses and the 4.7 ohm 1/2 watt resistors as well.
Aug 16, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Auto convergence
Bull!!!!!!!!! i dont think he knows what hes doing....
you can send the board into ptscorp.com have them check it out, it's the board with big black iC stk392-XXX send that one in, you convergence is done thru the menu system.
Feb 15, 2008 | Philips 55PW9363 55" Rear Projection...
Convergence on tv gone bad
you could replace the convergence ICs yourself,it does require good soldering skill.
Dec 30, 2007 | Sony KV-35S45 35" TV
Replaced two IC's and still the same problem????
U say the set is bowed in from top, could this be a foldover? If so then the ic problem may not help. Check to see if any fluid leakage has dropped on your deflection board. If so then you probably will need to clean and replace some capacitors. This is kind of common with the philips projo's. Look around crt for fluid leakage and on board.
May 19, 2007 | Philips Magnavox 9P6034C 60" Rear...
Convergence problems with model#9P6040C101!
They are large black colored IC's with the markings of STK392-xxx (xxx could be 110,120,150) There could be open resistors as well and you have to make sure if you do replace the IC's that you apply heat sink compond to the back of them otherwise they will prematurely fail.
May 03, 2007 | Philips Magnavox 9P6034C 60" Rear...
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
