Question about Bionaire BW2300 Window Mount Fan
Need to dismantle Bionaire wondow fan Model BW2300
The fan needs to be cleaned. Removed all the screws, but there are clips that hold the "accordian" extender screen and does not allow us to separate the front and back panel.
No mention in the Instruction leaflet how to dismantle fan to clean it. Anyone have any luck doing this?
Thanks
2 Suggested Answers
SOURCE: how to set the temperature
Look up this fan on amazon.com. In the comments/reviews a gentleman posted instructions for fixing the thermostat (it involves opening up the fan and repositioning the thermostat wire).
Posted on Aug 11, 2007
After cleaning the fan it won't power back up
wow... you must have got it really wet ! but if that is why it is not working now, then set it out in the sun for a few hours, or put it in front of another fan. hope this helps. post if it does. There are other problems it could be and I may be able to help with that as well. first things first. good luck. Tim
Sep 12, 2012 | Bionaire BW2300 Window Mount Fan
Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
Apr 16, 2009 | Bionaire BSF1731RC Stand (Pedestal) Fan
Cleaning inside the fan
Unplug the unit from the wall for safety. Remove the two screws in the upper hand grip recess (upper back of the unit). The two screws must be completely removed (not just loose and setting in the holes). Once the two screws are out, the back half of the fan cover can be slid downward (some amount of force is needed to unsnap the two halves from each other but be careful since the parts are all plastic and can possibly snap). Once the back is unsnapped from the front, you can lift the back half away from the front half and the inside parts are now accessible. I have found on my fan that it is the top fan shaft / bushing that is causing the squeaking noise that so many have complained about. I have found that periodically lubricating the top shaft/bushing will make the fan sound like new again - for a while. Every 2 - 3 weeks I need to clean (wipe off old lube) and re-apply fresh lube).
Jul 19, 2008 | Bionaire BT45RC Tower Fan
Not right
The controler electronics are probably failing, or the motors are starting to pull too much current. Get in contact with Bionaire to find out who their local service is in your area for parts and repairs.
Jerry G.
May 27, 2008 | Bionaire BW2300 Window Mount Fan
Water not draining.
You will need to remove the front lower axcess panel. There are 3 torx or 7mm Machine screws securing the bottom of the panel. Once the panel is removed you have axcess to the trap. Its the large plastic screw cap. Be ready to catch some water with a shop vac or other means.
Nov 24, 2007 | Kenmore Elite 45986 Front Load Washer
How to set the temperature
Jun 19, 2007 | Bionaire BW2300 Window Mount Fan
Red Light indicator on
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
Dismantling notebook.
Hi Beem, i will try and advise you if you want to send images of your laptop, from different angles so i can give ya ideas of how to get into it.. John auctionscotland@tiscali.co.uk
Jan 21, 2007 | Samsung X15 Notebook
Bionaire BW2300 Window Mount Fan Logo
60 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
