Question about Garden
Engine starts but wil not keep running - Garden
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 30, 2010
What does trouble code P1153 mean?
The upstream (ahead of the catalytic converter) O2 sensor heater circuit has failed. Replaced the upstream O2 sensor and all will be well. O2 sensors wil lnot work below 650 degrees F. To get them functioning sooner after a cold start, and during times when the exhaust is not very hot (idling at stop lights), designers placed a filament inside the O2 sensors to keep them hot so they can measure O2 levels int he exhaust stream (which alloows the engine compouter to mete out the right amonut of fuel to keep the engine running efficiently.) The filament fails open after time so it no longer can heat the sensor. The only solution is to replace the O2 sensor, which is not a big deal.
Jul 10, 2014 | 2001 Lexus RX 300
1992 Toyota celica starts and dies
Could be a sensor. Have it scanned would be my suggestion.
Aug 15, 2012 | 1992 Toyota Celica
My engine wil not start every time, I have changed coil pack, and switch and still it wont start everytime, the only way to start it is to push it and pop the clutch, (I have a manual transmission), it...
Since you changed your ignition switch, u might need to check the starter motor, if the starter motor pinion is jammed in flywheel ring gear. it can cause this. Also look at the starter motor solenoid.
Sep 09, 2011 | 1998 Ford Explorer
Over longer trips (over 30 miles) the car will chug lose power and stall. There is no engine light while this is happening. If I let the car sit a while it will run fine again. It almost feels like...
Well i would try cat. converter since if thay are faulty, sometimes when they get hot they entend not to work properly and keep the exhust in, so like holding your nose when you run.
Aug 23, 2011 | 2004 Volkswagen Jetta
R6 engine starts then runs and if u keep it running it wil run fine but if it stops wont restart again when u pull the choke its as if it is about too run but wont any ideas
Hi, sounds like fuel, however try testing the temprature of all four exhausts while the engine is running, poss spark plugs are fuel contaminaed. Care should be taken as the exhaust pipes close to the engine become extremely hot, but 1 exhaust not as hot as the others would point towards a fuel starvasion or a fould spark plug
Aug 12, 2011 | Yamaha YZF-R6 Motorcycles
The car will turn over and some times it wil start and some times it just turns overI and will not start.It has been to the dealer and they did not find what was wrong. The seat seems to work after he set...
If the car starts and runs fine when you first start it in the morning or when its cold from sitting for a few hours after driving it but won't start if you drive it somewhere and get the car upto operating temp and then shut the car off and try to restart it with a few mins or upto a half hour basically when the car is hot then you might be looking at a bad crankshaft position sensor. A bad crankshaft position sensor can keep the car from starting mostly when its hot. If the engine control module doesn't see that signal it doesn't know the engine is running so it never sends fuel to the injectors.
Oct 04, 2010 | 2001 Mercedes-Benz C-Class
My python remote starter when starting in the morning only wil will runl. On my 2008 dicota truck will run less than a min. And shot itself off only in thr morn.
You need to reprogramme the tach input, the engine is running colder in a morning and will run higher for a few minutes, during the day the engine will be warm and idle quickly.
Nov 21, 2009 | DEI Python 1400XP Remote Start/Keyless...
My 2003 GMC pick up keeps comeing up with a reduced engine power signal and i shut it off wait about 10 sec and it wil go for awihle but wil do this again what can be the problem
can be anything have truck scanned some auto stores such as auto zone / advanced auto do it for free the trouble code gives you a start point
Nov 02, 2009 | 2003 GMC Sierra 1500
Want start unless iput feul in the carb and then it want keep running
check the fuel line , the filter maybe clog. change the filter.
Jun 11, 2009 | 1991 GMC Sierra
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
