Question about Philips Health & Beauty
Repair philips bodygroom. The on off button is stuck in. how do i take it apart to repair
Hi, I've just fixed mine (accidentally). I took it to the repair shop and before I went there I'd left it in the car for a while with sub zero temperatures. The cold did its part on the switch which has some magnet or metal on the inside and it let go - it ain't stuck any more and it functions normally. Just PUT YOUR PHILLIPS IN THE FREEZER FOR 30 MIN and that should fix it. If you need more info e mail me on g_barbari@yahoo.com .
Posted on Mar 03, 2011
This procedure worked for mine too. Dear Mr Barbari, thank you for this brilliant idea to link the spontaneous healing of your bodygroom to the low temperature storage. And thank you for posting this. I put mine in the deep-freeze at about -18C for a few hours (wrapped in a plastic bag), let it warm up by itself and yes, I could hardly believe my eyes, the switch worked again. Incidentally, when my bodygroom malfunctioned, it switched itself on all by itself, in the middle of the night. It woke up the entire family and kept buzzing for about half an hour (you can't take the battery out). Hope this does not happen again.
Scanman
Posted on Mar 17, 2012
My model (European) had exactly the same problem as mentioned above. I took it to the repair shop, they opened it and saw in 1 minute the problem: the battery was dead. 1 of the 2 Varta V600HR batteries swelled up. Two new batteries (in the US 10,=) and the item is working as new again.
Posted on Nov 16, 2013
Works for me !perfect!
30 minutes in the fridge -18°C.
Let it warm up and enjoy !
Posted on Oct 25, 2015
Norelco repair
The blade assembly just pulls straight up and it will unsnap. Replacement can be found at shaveroutlet.com here:
http://shaveroutlet.com/norelco-philips-bodygroom-screen-and-cutter-for-bg2020-p-254.html
Sep 06, 2014 | Health & Beauty
I had a Bodygroom and had to replace it because the power button got stuck and wouldn't turn on. The new one was fine for a while but did the same thing. I have noticed that after a while it will work...
Same thing happened to me so I took the thing apart and that's all it took. The compartment that contains the battery and chip had a vacuum built up that prevented the button from being depressed. Once I opened it and released the pressure the switch worked again.
Apr 26, 2011 | Norelco Bodygroom Men's Total Body...
The Philips Norelco Bodygroom BG2040, does this model support multi-voltage charging ie. 100v - 240v? Or is it only 100-120v?
Welcome to Fixya,
According to the manual of The Philips Norelco Bodygroom BG2040, use only the cord and charging stand that was provided. Also you just have to plug the adaptor into 120V AC outlet.
If you want to know more about your Philips Norelco Bodygroom BG2040, just click here for the manual.
Hope this will help you and answered your question.
Thank you for using Fixya.
Feb 23, 2011 | Norelco Bodygroom Men's Total Body...
Hurts when shaving facial hair like its pulling it out
Check the shaver head for damage. Most likely, there is damage to the thin foil. If so, you will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/grooming/norelco-philips-bodygroom-screen-and-cutter-for-bg2020-p-254.html
Jan 11, 2011 | Norelco Bodygroom Men's Total Body...
I have a Norelco,Body Groom. The power button has gotten stuck in the on position. Is there any cure for this?
OK, I am incredibly impatient, so I just figured out how to disassemble the bodygroom on my own. The button issue is fixed quite easily as there is no spring.
To disassemble, I simply removed the silver/gray side plates. Then put an instrument in the blue hole and torqued it a bit and the fittings popped out of place and the top released. I recommend using some sort of plastic tool so as not to mar up the casing. Then, the guts are fairly straightforward. The button is just a piece of rubber with a rubber knob on the bottom. When you push it, it simply pushes a really small button on the motor. When it gets stuck, I am guessing the rubber knob has somehow gotten stuck next to the motor button. After you take off the top cover of the motor, the button should be back to where it is supposed to be. Just put everything back together in reverse order.
That fixed mine! Good luck!
Dec 16, 2008 | Norelco Bodygroom Men's Total Body...
Health & Beauty Logo
3,446 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
