Question about RCA Televison & Video
I need the Electronic Schematics for a RCA Model P60756BA Chassis PTK178LC
  • 4 more comments
  • egatzky Jun 07, 2010
    Hey There,I was asked kindly to check with you just for the System Control cct. diagram. He is trying to trace where the pin-out goes. The new Eeprom that we put in is running but nothing appears to be coming out. Please if you can help I sincerely would appreciate that.This on a RCA Model P60756BA Chssis # PTK178LC
    Kind Regards,
    Edward
    It has been tough, but I hope to find what I'm looking for.
    Thanks,
    Edward
  • egatzky Jun 15, 2010
    I tried this site and Mr. Kent stated he did not have the info. I needed for my Model...So it is frustrating to say the least. Thschematics have to be out there somewhere...There were 1000's of these sold in the day!!
    I don't have the specifics for what you ask...as I mentioned before I am helping out a friend that owns a Repair shop here to find the Specs. on the control system for my unit. I am a Nutritionist and Professional Fitness Trainer. Not an Electronics specialist. That is why I have turned to you for help. There has to be data out there...it is just a matter of finding it.
    Regards,
    Edward
  • egatzky Jun 16, 2010
    I will share this info. with Henry and get back to you thanks so much for the extra effort....I really do want to get this unit running again.
    Kind Regards,
    Edward
  • egatzky Jun 23, 2010
    Thanks for all your help...My Technician friend insists he needs the complete service manual for this unit. I have to this point have not had any success finding one. So I will continue to try and source one. I do appreciate that you have offered so much advice, that unfortunately has not helped. My Best wishes to you!!
    Sincerely Edward
    President:
  • 1,099 Answers
you can get the schematic at a price try the following website
http://www.jestineyong.com/?p=1496
jestineyong.com or electronicsonline help.com
Thanks for asking , Hope this will help
Posted on Jun 07, 2010
  • Sanyade Akinwale
    Sanyade Akinwale Jun 15, 2010
    if i get another one , i will let you know
  • RCA Master
  • 5,807 Answers
Hi
egatzky,
You can make a request on:
https://www.completeservicemanuals.com/index.php?_a=manualRequest
and here is another one:
http://www.servicemanuals.net/ServiceManual/GE/P60755ATLG1/212497/detail.aspx
all of them, only with a fee
Hope these helps
Posted on May 30, 2010
  • 37 more comments
  • egatzky May 30, 2010
    Thanks for the lead, but that is why I am paying for the fixya service...I don't want to keep going down a pathway that continues to pick my pocket..With all due respect i was looking to obtain the schematics through you ....
    KInd regards,
    Edward
  • Rommel Cana
    Rommel Cana May 31, 2010
    i don't have it either , but if you can possibly pinpoint what part in the schematics you are trying to
    find, then maybe we can sort it out.
    post what part number also.
    Post the regulator part number
    Post the Horizontal out Part Number
    Post the Regulator IC part Number
    Post the Jungle IC Part Number
    Maybe i can post likewise in pieces.
    Or try to explain in more details, the problem you are having with your unit.
  • Rommel Cana
    you may need at least 30 watts of Soldering Iron and a
    good
    quality Soldering Lead to solder the cold solder joints on the Circuits Board.
    How to
    solder boards properly
    How
    to test for Continuity
    How to use a multimeter
    Additional tip:
    you need to check circuits such as Horizontal Deflection
    have a check on the
    Flyback,
    Check the
    Horizontal Output Transistor
    . Either or both
    Could be affecting, Supply out your Power Supply
    Have the unit unplugged when doing a resistance check on the Board.
    Bleed or have the main capacitor ( power supply ) with a 4.7K 5W
    Resistor
  • Rommel Cana
  • Rommel Cana
    post what you need to find , specifically , So I might try to look for a possible " Free " Schematic
    Diagram link to match your Quest ( only if available ).
  • Rommel Cana
    I have uploaded one file for you to see, if it look s like your s
    RCA
    Service Manual 1
  • Rommel Cana
    On some, it just be a
    Resistor
  • Rommel Cana
    Rommel Cana Jun 01, 2010
    the second
    RCA Schematics 1
    is in djvu file format, you need a djvu viewer to view the file.
    Hope these concludes your Quest.
  • Rommel Cana
    here is a link , to one of the djvu viewer
    http://djvu.org/resources/
  • egatzky Jun 01, 2010
    I am not the Tech...I am just trying to find the info. for my Friend that is . I am trying to make heads or Tails of the link you sent me. If you could source the Chassis Schematics for that other RCA could you not source the same for my unit? I am a Nutrition Wiz and Fitness Wiz...Not electronics. If you could send me a link to obtain the info. I am seeking I would be very grateful.....Thanks for all your help thus far.
    Kind Regards,
    Edward
  • Rommel Cana
    then give me a part number on the circuit itself, sample are on my earlier post.
    a ) regulator part number
    b ) horizontal out part number
    c ) Jungle IC part number
    Even technicians have a hard time finding one.
    Most have with a fee, and some are not available or classified.
    Most often , Technicians have to do it the hard way, we call it " Mano-mano ".
    Schematics on earlier Models have similarities, only the designation or reference numbers ( not the
    actual part number ) are different on succeeding models .
    Schematics are just a reference , Tools , equipment , Knowledge and the know how are needed,
    depends on the success of your work.
    Actual parts are different and as often there are no more available parts for replacement. due to age.
    The links I have given you is enough to have the unit working.( Unless you cannot comprehend what it
    is all about. ) Servicing is not literally speaking it is on the mind of the techician.
    Must learn to " Divide and Conquer ".
    Divide meaning look for a certain part then conquer it, Start with the power supply,
    give me something to work on, not a guess!.
    Feel free to ask more clarification..
  • Rommel Cana
    here are additional info for you:
    Good response, It has to do with the power supply...System Control. The Unit is not pwering up and we replaced the Eeprom and H V Splitter.....Hoping all would be good, but after running for a couple of days the unit powered down. So there it is bro..Any and all help is appreciated. I will ask Henry for some part numbers that you seek......
    Thanks for your help this is cool,
    Edward
  • Rommel Cana
    Rommel Cana Jun 02, 2010
    Since you had it working then , most probably you may need to start all over again.
    Measure the
    Voltage for horizontal transistor
    and the
    Flyback
    Use the Tuner Metal chassis or the power supply secondary ground as your reference ground ,
    Meaning negative of the Multimeter ( Analog Multimeter is OK ).
    For whatever power supply ( many variations ) these horizontal deflection circuits
    will work for as low as 95 V, You may need a Variac to have the Main AC line supply reduced.
    And measure the Usys B+ of it.
    Only on some you, may have a smaller raster compared to the Normal operating supply voltage.
    But that is for troubleshooting purposes only.
    here are the output voltages of the power supply:
    Usys B+ should not exceed more than 130V.
  • egatzky Jun 02, 2010
    I'll get back to you bro...I'll pass the info. onto Henry. Thanks.
    Edward
  • Rommel Cana
    All of it, including the links
  • Rommel Cana
    Since you have replaced the High Voltage Splitter might as well check voltages for the G2,
    Check if the " Heater " Supply is available
    As well as the +200V line that goes to the Video Out Circuits ( Cathode of each CRT )
    Of which you will never have, unless the flyback oscillates.
  • egatzky Jun 03, 2010
    Hi There, I spoke to Henry and he indicated that it is the System Control cct. Diagram that he needs.....He is trying to trace where the pin-out goes to. The Eeprom is running and nothing is coming out as he stated. Where does the signal come out? I sincerely hope you can help with this.
    Kind Regards,
    Edward
  • egatzky Jun 04, 2010
    Hey There, I was looking forward to getting back a response...Henry asked me kindly to ask you just for the System Control cct. diagram. He is trying to trace where the pin-out goes. The new Eeprom that we put in is running but nothing appears to be coming out. Please if you can help I sincerely would appreciate that.
    Kind Regards,
    Edward
  • egatzky Jun 06, 2010
    So have you given on me?? lol Please let me know if you can offer insight with respect to my most recent query.
    Kind Regards,
    Edward
  • Rommel Cana
    Rommel Cana Jun 08, 2010
    give me some of the part number that i need ,
    although you may have the right model , on some, actual parts are not the same
    service manual is just a reference.
  • Rommel Cana
    There are also precautions on the service manual, that you need to have a Chipper Check before
    replacing any component
    What you may be looking may not be available , if you insist on the schematics, you need the full
    service manual plus the manual and guides for the Chipper Checker including the software and
    hardware to finish you project.
  • Rommel Cana
    Thanks for choosing Fixya for assistance!
  • Rommel Cana
    Rommel Cana Jun 15, 2010
    Thanks again for choosing Fixya for assistance, It appears that my information was not
    helpful. I cannot help you, if you do not respond with further comments or questions
    so I can assist you further..
    I do have some Solutions , that might possibly Work, But it would be better
    if you could give More details not a guess.
  • Rommel Cana
    you are right , and it is on my first post to you.
  • Rommel Cana
    and what will i find exactly , if i do not have the part number of the one you are wanting to look at.
    Every unit has its own matched components , dependent on where it is manufactured.
    to be sure i am giving you the right one provide me the details.
    How can I confirm and check , if it is really the one you are wanting to have.
    send me an image if you cannot read it, i will try to , if possible.
  • Rommel Cana
  • Rommel Cana
  • Rommel Cana
    or you have a trouble putting back the resistor ?
  • Rommel Cana
    here are some guides to look at:
    and for the Micro
  • Rommel Cana
    and these might be your Jungle:
  • Rommel Cana
    Rommel Cana Jun 16, 2010
    thanks for choosing Fixya for assistance!
  • Rommel Cana
    Rommel Cana Jun 23, 2010
    here is an additional info for you:
    Place a scope on pin 5 or pin 6 of the EEPROM U3201 and plug the TV in.
    You should see data for an instant then it will go away.
    If data is there all the time, the EEPROM is corrupted
  • Rommel Cana
    Just like I said, I need the true part number that you have on your TV, those above will be your guide
    but the concepts are all the same,
    One way to troubleshoot something is to " Divide and Conquer ".
    Anyway , thanks for choosing Fixya for assistance, I could have helped you further , only
    if you have given me the part I need.
    Use a oscilloscope when tracing for data on my last post., Good Luck!!
  • Rommel Cana
    And have your Technician , trace for a possible open resistor ( could be near to it )
  • Rommel Cana
    and these is what it may looks like :
    ( sample EEPROM only )
  • Rommel Cana
    Rommel Cana Jun 24, 2010
    on some they have made it like these
    but it could also be using like one of these
    Just for troubleshooting purposes only.
  • Rommel Cana
  • Rommel Cana
    Rommel Cana Jun 25, 2010
I'm looking for a tv tuner RCA projection tv model no. P60756BA
shopjimmy.com the board in your photo is the switch mode power supply
Jul 23, 2014 | RCA Tuner/input Board 30900192
I need the schematics of the control module
The model listed is an older set----usually if it HAS the splitter it is up front----but most there is not one as it is part of the high voltage transformer----look on the label on the rear where model number is for a Chassis number, that will tell me instantly if a splitter exists or not PTK-------
Nov 05, 2012 | RCA P52926 52" Rear Projection Television
RCA D52W20 ATC221 TV Schematics/Service Manual
go to www.tvrepairworld.com they can assist you and they have all the components for the RCA ATC and ITC series televisions and very knowledgable staff for RCA problems based on symptoms.
Apr 09, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
RCA Projection P52937SG Continually changes channels
your model has the PTK195 chassis you can get the service manual and parts at the following link. They email the manual and also provide free tech support to help you with diagnosis.
http://servicemanuals.vstore.ca/
May 03, 2008 | RCA P52937 52" Rear Projection Television
Rca hd-61w66 chassis itc222 convergence
you can get the service info at the following link. send them an email by clicking on the contact button on the lower left side. they have schematics as well as parts.
Apr 22, 2008 | RCA P61927 61" Rear Projection Television
Rca dlp schematics
what chassis number is your set? Should be an ATC number on the rear of the set. Let me know that number as each series DLP is different for voltages
Feb 15, 2008 | Televison & Video
RCA color tv,model 27F520T,Chassis M134C
On the tv panel push and hold volume down until volume is all the way down and keep holding, then push the info button on the remote.
Dec 21, 2007 | RCA TruFlat 27F520T 27" TV
Tuner Trouble
You will have to order this through an authoized RCA dealer Its not old enough yet for general publications from RCA If you call Sherl at TEEVEE Supply at 1-866-207-9824 or sales@teeveesupply.com give them the CHASSIS number NOT the model and they will order you one. You should know my freind when dealing with RCA alsway go by a chassis number! Good Luck
Jul 26, 2006 | RCA 35V432T 35" TV
Televison & Video Logo
157 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
