Question about Car Audio & Video
I need to check American legacy amp before I buy it
    Scholar:
  • 84 Answers
Give it power, ground, and remote turn on and put a sub on it quick it should kick on and stay on and push your sub. If it doesn't it's probably not going to work and isn't worth fixing. Personally I wouldn't buy it in the first place, save a little more cash and buy a quality amplifier. That's actually one of the most important parts of your system.
Posted on May 31, 2010
5 Suggested Answers
  • 883 Answers
SOURCE: what size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Posted on Dec 13, 2007
SOURCE: i have an american legacy series 2 1000watt apm
If the fuses were the problem then you would be replacing them all the time. Fuses are only good once - and are only in place to protect the circuitry from damaging overcurrent situations.
More likey, the problem is a thermal protection resulting from over-driving the amplifier. What impedance are the speakers you are running? Does the amplifier support that impedance? Typically, car audio runs 4-8 ohm impedance. Many amps have a switch to place the unit in the proper impedance mode.
Check your wiring. Do you have it wired correctly?
Posted on Apr 03, 2009
SOURCE: my amp
My amp stays in protect mode i don't know whats wrong Any suggestions
Posted on May 14, 2009
  • 19 Answers
SOURCE: I have an American Legacy Series 2 1600 watt amp.
try a 30 thats whats in my leagacy but its an 850 amp if it pops the 30 go up to 40 and so on i wouldnt go passed 60
Posted on Dec 15, 2010
I need to know the size of external fuses for a american legacy amp 2000 watt 2 channel 1990
25 to 30 amp fuses will work great, anything lower could possibly blow a fuse when a good bass note hits even if there is nothing wrong with the amp. Hope this helps.
Jul 09, 2010 | Legacy - American II: 2 Channel 2000W...
My amp
Apr 05, 2009 | Legacy Audio American Legacy II LA1990 Car...
I have an american legacy series 2 1000watt apm
Check and see what size fuses it uses. Your watt power means nothing without good fuses. My suggestion would be to go buy 40a fuses and replace the ones you already have.
Feb 27, 2009 | Legacy Audio American Legacy II LA290 Car...
600w legacy amp
9 times out of 10 if your amplifire is in protect mode and evrything externaly, like speakers, fuse, voltage, etc. checks out fine then
either you have shorted out output transistors or power mosfet transistors. Basicly that just about what happens with car amps.
It's easy enough to fix IF, IF you know what your doing. First you
need to check the output transistors with a digital volt meter on diode check, If they check out then check your power supply mosfet transistors. I can almost guarantee this is your problem. Very common. I buy non working amps all the time and repair them. Listen to pbabin also he has helped me out. Good luck
Sep 08, 2008 | Legacy Audio American Legacy II LA490 Car...
Problem with legacy amp
I would check the RCA preamp wires connecting the stereo to the amp. If these are loose or broken, it could cause you to lose your sound.
Does the amp show signs of life, such as clicking on, an LED turns on, or anything like that?
Has anything else changed between the time it worked and didn't work?
Mar 20, 2008 | Legacy - American II: 2 Channel 2000W...
What size fuse do i need for amp
600 watts = 12x
x = 50 amps
Dec 13, 2007 | Legacy Audio American Legacy II LA490 Car...
Amp dosnt hit hard
what is the rms and ohms fro the amp and what type of subs and how many
Dec 07, 2007 | Legacy Audio American Legacy II LA290 Car...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
