Question about Pioneer PDP-5071HD 50 in. Plasma HDTV
No sound from TV or speakers - Pioneer Plasma TV, Dennon Receiver
No sound when in TV mode. Have sound in DVD and Tuner modes.
Connection is from DTV is (1) to DTV receiver (2) to system receiver (3) to TV.
Changed to alternate HDMI Input, no luck. Mute is NOT on.
Help?!
  • 41 Answers
SOURCE: Upgrading media receiver on Pioneer PlasmaPDP-5030HD
You can use a PDPR06U if you can find one for sale its 2 generations later than your's. Look on Ebay. I might have one too but I got to look.
Posted on Mar 29, 2009
SOURCE: The media receiver shuts off and the plasma screen
Pioneer plasma pdp R03U shuts off and tv shows E01 or action freezes while soun dgoes on and then stops E01
Posted on Jul 19, 2010
BElectric
  • 1140 Answers
SOURCE: i have a Pioneer PRO
The first thing you need to do is establish whether there is an actual fault with the MR or whether it's a setup/connection issue. You haven't indicated anything you have already tried in order to rectify the problem so I'll have to start at the beginning with the basics:
Isolate the MR
1. Make sure the MR power is off using the "POWER" button on the front of the unit.
2. Disconnect ALL cables from the back of the MR. If you have several connections be sure to make a note of where they all reconnect
3. Unplug the MR from the power outlet and leave disconnected for at least 5 minutes.
The software/firmware in a MR can "crash" in the same way that your PC does. Unplugging it for a few minutes should re-boot the system - basically the same as starting up your PC.
4. Plug the MR into the power outlet again but do not connect any cables.
5. Switch the MR on using the "POWER" button on the front of the unit.
If the MR is still stuck in standby, you have a fault with the MR.
If the MR will power on:
6. Switch the power off again and re-connect the cables for one device at a time then test the MR. Make sure the cable are connected to the correct sockets.
I suggest you connect the TV first then test the MR will power on. Next connect the cable box and test the MR again. If everything is OK, continue to connect any other devices one at a time and test the MR after each connection.
If the MR fails to power on after connecting a specific device, this will give a good indication of where the fault is and what to do next.
If you can re-connect all of the devices and the MR functions correctly, then it was just a simple case of the MR having "crashed" and you can resume normal operation. Should the fault re-occur, simply unplug the box, leave for a few minutes and switch back on. You can avoid disconnecting everything unless the box fails to power up after the "hard reset" - i.e. unplugging it.
This is a very simple test to determine what/where the fault is. Please try all of the above and then post back with the results if you need further assistance.
Regards,
BElectric
Posted on Jan 09, 2011
Hello, I to had this problem, and my original media receiver finally died. I did however go to my local electronics store ( I'm not talking about the big box stores) And bought a $7.00 dvi to hdmi adapter. I simply unplugged the "system cables from the back of the media receiver and placed the adapter at the end of the DVI side of the cables, and plugged the now hdmi side into my hdmi splitter box and I am off and running! The only downfall is it does not carry sound only video. But this in not a problem for me as I have a surround sound system. This was a very inexpensive fix for me/ I hope this helps.
Posted on Jan 28, 2011
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
Pioneer 409 setting up for surround sound
I think there is a switching problem in the surround receiver. I would take the receiver to a qualified servicer. There is nothing user serviceable in the unit. Question .Why are you using optical output from ps3. I recommend you connect all you a/v devised to the tv. Then connect the opt out of tv to receiver. that way what ever you are viewing will send audio via opt out of tv to receiver. that way you do not have to switch input on receiver. Hope this helps.
Jan 07, 2014 | Pioneer VSX-D511 Receiver
My HTR-6060 plays through the tuner and dvd but not the DTV/CBL
Digital settings need to be assigned by the receiver in the ption Menu >> Audio Select.
Check the one for the HDMI from DTV/CBL.
May 23, 2010 | Yamaha HTR-6060
I have no sound through my surround sound when playing ps3
The optical audio out from the TV only works for the TV's tuner, probably. Hook-up optical from Cable/SAT and from PS3 boxes to DVD/Receiver.
Apr 20, 2010 | Pioneer PDP-LX508A 50 in. Plasma TV
Sound from tuner but no other devices
The RX-V365 cannot process audio from the HDMI cables (you will still be able to hear it on your TV), you will need to run a seperate coaxial or optical cable into the audio input for the relevant component on the back of the RX-V365.
Dec 26, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Sep 24, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
My speakers arn't working with my new t.v.
Any sound from other sources ie. a CD/DVD unit, Tuner etc.? If so then the issue is the signal path fron the TV to receiver, What cableing do you have from TV audio output? Try standard analog 2 channel to the receiver tv in, be sure you select TV on the receiver mode,also check the TV sound menu options, some require that you disable TV speakers and use the audio line-out option fixed or variable.
Feb 01, 2009 | Pioneer VSX-815-K Receiver
Surround sound
I need to details from you.What other components have you connect together?
solutiondoct
Sep 06, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Denon 4308
ok sounds simple you ran the lines threw the tv instead all lines should be ran threw the sterio
see once you turn tv off this cuts the outputs out so now no sound will happen
your sterio should be equipted to take inputs of tv
you want everything to be inputed threw receiver thats why they call it a receiver the outputs on tv goto inputs on receiver
you need to redo your wireing so that this which i described is correct again
Jun 01, 2008 | Denon AVR-4308CI Receiver
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Open Questions:
Pioneer PDP-5071HD 50 in. Plasma HDTV Logo
381 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
