Question about Savv Televison & Video
I am trying to find out whether this system #LOH-5090DVD ,the audio play through my vehicals sound system, and if so what buttons do I need to push in order to do so.
3 Suggested Answers
SOURCE:
pankaj_dic
  • 1252 Answers
SOURCE: aftre reformating my sound play anymore
yes you have to install the sound driver, for this go toshiba site download it from there
Posted on Nov 16, 2008
bunnydawg
  • 5158 Answers
SOURCE: Hi! My DXZ545MP CD Player
first kelly... if you don't already have it .. here's the manual...
http://www.clarion.com/ca/en/MungoBlobs/754/615/DXZ545MP(Manual),1.pdf
you can reset that by unhooking the battery for about 10 minutes and hooking it back up... if that is an anti-theft type radio make sure you know the code and how to enter it. you'll have to set the pre-set stations again too.
Robert
Please take a moment to rate this solution thanks.
p.s. just noticed how long ago you posted this. you probably have it fixed by now... but the manual may come in handy to you
Posted on Apr 19, 2009
97 ford expeditions front power windows do not go down when vehical is running. They sometimes will work if you push the back window up button and the front windoe down button at the same time. They also...
Sounds like window regulator switch is bad or contacts need cleaned. If they are intermittent then it is likely a wiring or switch contact issue
Sep 24, 2013 | 1997 Ford Expedition
Aiwa stereo is working but no sound
try crossing over your speaker wires , criss cross them from like A top and B bottom. then there ussally are 2 button that control the speaker out puts. Find the buttons and try pushing them in and out until u get sound. hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_e9d0abd7cc2508b3
Jan 25, 2013 | Aiwa Audio Players & Recorders
I cant hear myself , my audio isnt working
Check for whether the Audio Driver is Working .Also check the sound and audio in the control panel (Whether it is muted or not) .Reinstall Driver If the problem persists . Reinstall OS if necessary
Microsoft Windows Sound Card Test There are also several test that can be performed from Windows. Microsoft recommends the following procedure:
"Verify that Windows can play .wav files:
  1. Click Start, point to Settings, and then click Control Panel.
  2. Double-click the Sounds icon.
  3. Under Events, click an event that has a loudspeaker icon next to it.
  4. In the Name text box, be sure that the three-letter file extension is ".wav".
  5. Under Preview, click the Play button. You should hear a sound.
If you don't hear any sounds, or if Windows is not able to play a .wav file, check to see that a sound driver is enabled:
  2. Double-click the System icon.
  3. Click the Device Manager tab.
  4. Click the plus sign next to Sound, Video And Game Controllers.
  5. If there is no Sound, Video And Game Controllers entry, or you have no sound card listed under this entry, contact the manufacturer of the computer or sound card and request help reinstalling the sound card drivers.
  6. "
Dec 12, 2010 | Computers & Internet
Connot play sound in my pc desktop. os window xp professional. model-compaq pressario-gs178aa-acj sr 5420il
Try one of these solution:
1.Try to get the latest update for your XP OS. (i. e latest service pack and update)
2.Try to download Driver for the audio to function properly (if it is external)
3. If you have a built-in sound controller Try to install your motherboard driver to update all its chipsets
4. Check your hardware stability by right clicking the my computer on the desktop,select properties,select hardware tab, select device manager button,under the sound, expand to see all the listings, check to whether audio devices are present.
5.Try to check in the control panel,select sound speech and audio devices,select sound and audio devices, click sounds tab,under the program events select one of those programs and click the play button if sound can be heard.
Sep 27, 2010 | Compaq Computers & Internet
Sound doesn't fully play
Try updating the audio driver.
If that doesnot help, check whether there is any sound manager installed on the computer.
May 31, 2010 | Dell 5650 Computer Speakers
My latops speaers are not givig out sound. i am using windows 7
First check whether the audio volume is not muted, and turn the volume all the way up, if you didn't already try that.
Did you try playing the system sounds? Enable them from the Control Panel (double click the sound and audio devices icon from the Control Panel), if you didn't try them, or if they aren't enabled. Then, play one of the system sounds from the "Sounds and Audio Devices" (second tab, labeled sound).
Can you see a speaker icon in your system tray? If yes, double click it. Do you get the 'Master Volume' control or do you get a message that says something like you don't have audio enabled?
If you get such a message, then the audio drivers are missing or corrupted, or not properly installed.
If you can open the Windows Device Manager, open it and check whether the sound drivers are present and are functioning correctly.
(For opening it in Windows 7, open the Control Panel from the Start Menu. Click on the System and Security link. In the System and Security window, click on the Device Manager link located under the System heading.  (Another easier way is to click the Start button and type the following command in the search box: devmgmt.msc Then, hit the enter key.
In Device Manager, expand the 'Sound, video and game controllers' (click the plus sign next to it). See that the sound driver is listed. Double click the item in that list that contains the word "audio device" in its name. Does Device Manager say that the device is working properly?
Instead of manually searching for the drivers, or your old drivers CD (you probably don't even remember where you kept it), you can download this driver scanning tool from here: http://xpdrivers.com/index.cfm or directly from this link: http://xpdrivers.com/download/download.cfm
After you download it, double-click it to install it and follow the simple instructions and run this tool to scan your system. It will inform you and update the needed sound drivers.
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit http://xpdrivers.com
Some FAQ about laptop sound and Windows 7: http://windows.microsoft.com/en-US/windows7/Sound-cards-frequently-asked-questions
Mar 19, 2010 | Recoton Advent Audio Players & Recorders
What is the average cost for cv axle repair/replacement?
jack car up the side u suspect and see if there is any play in weal and grab both side of tire push and pull light becare full and dont drop car on you dont tug on like yor trying rip tire of
Jan 03, 2010 | 1996 Chrysler LHS
1 yr old baby playing with the remote and now there is no audio/sound coming from the TV. what can we do? I tried menu and audio settings, but nothing worked so far. we don't have any audio equipment...
Try the SAP button (the one you push for spanish on second track). Sometimes there can be a position where no sound comes out so a person can use a surround system etc.
Aug 03, 2009 | Sharp Televison & Video
Hi! My DXZ545MP CD Player had some buttons pushed by my dog in the car and now the volume no longer works. There is no sound at all regardless of the volume levels and it simply stopped playing music once...
Robert
Jan 01, 2009 | Clarion DXZ545MP CD Player
Sound problems
What`s the model no. of the music system,
Please check whether the system is in Karoke mode ?
Regards,
Aby Paulose
Dec 21, 2007 | Audio Players & Recorders
Televison & Video Logo
54 people viewed this question
Top Savv Televison & Video Experts
Ekse
Are you a Savv Televison and Video Expert? Answer questions, earn points and help others
