Question about Lexmark X4580 InkJet Printer
Where do i put the ink catridge - Lexmark X4580 InkJet Printer
    Genius:
  • 1,354 Answers
Hi
just go to below link you will know how to change catridge
http://www.youtube.com/watch?v=uVaP5r1D6pg
Posted on May 30, 2010
How do I insert the ink cartridge
power on the printer, open the catridge door. after printer initializes the catridge carriage assembly comes to right side of the printer and settles then insert the catridges and close the door.
Oct 17, 2014 | HP Office Equipment & Supplies
I put a yellow ink cartridge in printer and it is new but the printer is saying yellow cartridge is empty so i am unable to print anything what do i do
Did you remove the plastic Seal undernith your ink Catridge, also check for any dry ink deposites where the yellow catridge sits in the catridge carriage box, if present use an alcohol cleaning pad to clean the carriage and re-install and verify.
Dec 03, 2010 | HP Officejet 6500 Wireless All-in-One...
Tells me ink needs replaced even after putting in new ink.
check your new ink catridge and look for a mini green electronic chip if that is damaged the printer shouldn`t recognize the catridge
May 16, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Replaced the ink. black works colored does not.
Normally, new catridge has a thin layer close the output of the ink. See that thing. If it close, pull it over, Or.
May be the catridge is not suitable with the printer.
May be the the catridge is quite old and the ink is dry, if it is refill catridge, put several drop of hot water in it.
Hope this may help.
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
Can i use my scanner without putting in a new ink catridge in
no,both ink cartridges should be installed into the printer.buy new ink cartridges from kodak online store if u want to buy.
Jul 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My hp 1310 says no colur ink catridge found.
No
some model hp deskjet all in one used duel cartrdge because it is a color popier
Jun 16, 2009 | HP PSC 1315 All-In-One InkJet Printer
Check Ink error on my printer and unable to clean to try and fix
Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer.
Good Luck :)
May 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Lexmark 5400 Printer does not use the photo cartridge
First of all as this Catridges are Non Intelligent they will not be able to show u the exact Ink level on the catridge then too if thats really happening this Solution below will fix it: In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the Photo on the left........ Good Luck
Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer will not start after changing ink cart.
u better remove both catridges ,switch on the printer ,after that the print catridges lights will blink ,open the cover the catridge holder will come at the centre,put the catidges n perform the catridge alignement,n complete it
Dec 19, 2007 | HP Photosmart C3180 All-In-One InkJet...
Lexmark X4580 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
