Question about Sta Rite Sta-Rite Max-E-Therm Low NOx Pool and Spa Heater - 333K BTU Heavy Duty / Natural Gas
The heater won't start. The temp reading is 126 F all the time. The thermistor resistance changes with temp change. No diagnostic lights are on. Does it need a control board or is there another test?
Mine is doing the same. StaRite/Pentair tech support says the thermister needs to be replaced. I have one on order and will update on my status when I get the part replaced.
Posted on Jun 14, 2010
  • chipwheels Jun 23, 2010
    Replace thermister on the intake of the heater.
  • jimtee58 Sep 20, 2011
    I had the exact same problem listed here (having a 126 on the control board for the Sta-rite heater). After reading these updates, I decided to order the part and I installed it this afternoon. It was the right answer for my problem.
Inlet thermistor open f24
A thermistor changes in resistance with changes in temperatures. As the air is drawn out the dryer into the blower and discharged out the machine, the resistance changes made by heat differential is monitored by the control. If the control cannot get a reading from the thermistor it does not know what the temp is inside the dryer so it declares an error and shuts down. You must not only replace the thermistor you gotta clean up the innards to do the job right. Their are videos on yourtube which show how to replace a thermistor in a dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 11, 2014 | Dryers
Re ignite pilot light
Must be a bad sensor. These new fangled models use electronics to sense the heat. In the place of a control klixon, they use a thermistor. The thermistor changes in resistance with changes in air temps. The fancy shocktronics upstairs monitors the thermistor for resistance. if it cannot read any resistance it shuts down. Measure the thermistor for resistance if ya cannot get a reading or it is out of spec then replace it. Another thing is the small belt on some of these falls off and the blower stops working. The dryer quickly overheats and shuts down. c89c5b39-d34b-41c4-be20-63c931f4d786.jpgYou can access a service manual by going to appliancejunkgoogledrive and accessing dryer service manual section.
Sep 18, 2013 | Whirlpool Dryers
We have a SR200 NA Sta-Rite heater on our pool. We just replaced the thermistor today. Now the digital temperature readout keeps jumping back & forth between 91 & 104. (water temp. was only about...
That unit has specific instructions for water temp operation at 60 or lower. The display also can show diagnostic info and there are indicator lights for diagnostics. Do you have any of those showing any errors? If the temp is jumping from 91 to 104 instantly and then back down to 91 instantly, this is a wiring issue or a bad thermistor. Check the wiring and use an OHM meter to check the thermistor, it should have a chart that shows a resistance at a certain temp. There is a limit switch right next to the thermistor, Make sure it is not shorting out with that.
Nov 20, 2017 | Sta Rite Pool & Spa
Pentair Master Temp Heater is not heating and reading 126
Definitely bad thermistor Pentair reps have seen this happen a lot. Lick finger and touch the two contacts where the thermistor plugs in it should fire up if it's a bad thermistor. If you do an ohm reading you'll find that the ohms do not correlate with the temperature that's displayed. I just trouble shot one and I'm getting 51.2 ohms which equates to 10 - 20 degrees Fahrenheit which is obviously not what is being displayed because it's 126 which is a common number that's displayed when a thermistor is not reading properly
Aug 28, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Water Temp on heater reads 126 degrees F
I am not sure if you have resolved this issue, or not, but just in case. Yes, the problem is the Thermistor. This is a sensor that "reads" the incoming water temp. It is really easy to replace as well.
Jun 29, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
Jun 22, 2009 | Sta Rite Sr200lp Max E Therm Pool & Spa...
When Heater is turned on display shows 125, doesn't ignite/fire.
I am not sure if you have solved this issue, or not, but here is one idea. When you turn on the heater, it is reading the temp at 125/126 correct? IF this is what the heater is reading, then the problem is the Thermistor,or temp sensor, and is very easy to replace.
If you have an Owner's Manual, there are part numbers and instructions on how to replace the Thermistor. If you do not have one, follow the link below and it will take you to one online:
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
Jun 22, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Error code 126
This is a bad thermister or heat sensor. It mounts in your water manifold and if it goes bad no error will show. The bad sensor is telling the heater that the water is to hot and it wont let the heater fire. This is a farley inexpensive part and easy to change out. With a new one it should read the proper temp and call for heat then fire the heater. Good luck.
Jun 17, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta-rite gas heater will not go on.
Part of the ignition system is bad. It is probably the ignitor, if you change it shut main gas supply to unit. Also, shut the power to the heater and turn it back on after repair
Jun 08, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta Rite Sr333na Max E Therm Pool & Spa Heater gauge stuck?
Anytime the heater is reading the water temp to be above what it actually is, especially 126, the problem is the Thermistor, or Temp Sensor, for the heater. This is a very easy part to replace. The Thermistor is located on the manifold, on the left side, between the top two bolts.
Sorry this is a late response! Hope that it helps!
Apr 10, 2009 | Sta Rite Sr333na Max E Therm Pool & Spa...
Sta Rite Sta-Rite Max-E-Therm Low NOx Pool and Spa Heater - 333K BTU Heavy Duty / Natural Gas Logo
415 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
