Question about Microwave Ovens
GE Microwave Oven Model JES735 700Watts
Side of microwave is warm even when not using. Is this normal and OK to continue using safely? Everything works properly on it. HELP.
Thank You,
Dan Shema
  • Microwave Ovens Master
  • 9,098 Answers
As long as it's not too hot to touch, and you feel air moving through the vents when it's running, it should be okay.
Posted on Apr 18, 2008
GE Profile microwave oven PEB7226SFSS quit warming food but appeared to be on/operate with light on/timer counting down. Installed door switches-now the microwave "works" only when the door is open
Sounds like on reassembly you reversed wires to door switch.
switch might have letters C NO NC (common, normally open, normally closed) one wire goes to C common, the other to NC normally closed. Try reversing the wires.
If you use meter measuring continuity meter on C and NO should be high resistance until you press switch.
meter C to NC measures low resistance until you press switch then measures high or infinity (open)
Sep 28, 2016 | GE Microwave Ovens
My microwave does not warm and no light the motor for warm does not come on the timer is working fine and all the lights are good it a GE model JES1142WMC01
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Jun 08, 2011 | GE JES1142SF Microwave Oven
My GE spacesaver Microwave oven is not warming anything up. All other functions are working normally.
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Jul 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave making dull thumping noise when NOT in use
I called a technician out today. Seems like the problem is the circuit board. It wasn't working properly and the sound is the fan. The fan is supposed to turn on when the microwave is in use and off when it is not. In this case, the fan continued even when the microwave was not in operation. A new circuit board has been ordered and will replace the old one when it arrives. For now, I can still use the microwave, but I have to unplug it everytime I finish heating something up. A little inconvenient, but at least it'll still heat my food up in the meantime.
Jun 24, 2009 | GE JVM2070 Microwave Oven
Is my dented microwave safe to use?
Hello carillon553,
If you haven't compromised the door opening or inner compartment, then it is more than likely OK to use. The magnetron ( which generated the microwave energy ) has a waveguide that focuses that energu into the cooking compartment and a small dent to the cabinet normally has no impact on its safety.. Hope that helps..
If you are overly concerned with that, then you would need a technician that has an RF Power Meter to check it.. If it were me, and the dent was small.. I would just use it...
Regards,
Rick
Dec 13, 2008 | Danby DMW1153 Microwave Oven
Why is the paint bubbling inside microwave
The paint or inside in my microwave oven was bubbling up. I didn't think much of it until my husband came down with tongue cancer. He didn't smoke or drink. The only thing that was strange was the way my microwave was bubbling up inside. We were given very grim news, but in time and by swithcing hospitals, my husband is now ok and has been cancer free for 5 years. If ever my microwaves start blubbling up, I throw them out, it wasn't worth the health hazards.
Oct 24, 2008 | GE JVM1650 1000 Watts Microwave Oven
Auto-fan turns on too often.
Normally the exhaust / vent / hood fan will come on automatically if the stove top or the bottom plate of the microwave gets too hot.
Also, there may be some settings for the auto-fan that can work like this.
Consult your manual. If you don't have it, you can download GE owner's manuals and installation instructions here.
Otherwise, the hood fan thermostat may be failing. It should be normally open when you do a continuity check.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
We even have a video on our site that shows you how to safely & easily remove the control panel assembly in less than 5 minutes so you can check out your oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Metal pot
The magnetron may have gotten overheated. This could very well shorten its life.
Of course one should never leave a microwave unattended while it's running, but this rule is even more important for this oven now.
I would just use it as normal but keep an eye on it. If it clears up, good news. If it gets worse, then please reply back and let us know what your new symptoms are.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 23, 2008 | GE JE1460 Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
