Question about Singer 3116 Simple
My Simple Singer sewing machine will not thread the bobbin thread. For some reason it will not pick up the bobbin thread from the bottom of the machine, does anyone know how to fix this problem?
  • Nina Scrabeck Jun 01, 2010
    check the needle. is it inserted to the top of the needle bar?
    Genius:
  • 1,788 Answers
Your needle may be in backwards, flat side should face rear of the machine or you bobbin is unwinding in the wrong direction, refer to your manual and dvd. Call Singer at 1-800-4singer if problem persists. Good luck
Posted on Aug 27, 2010
Simple singer 3116 isn't picking up bobbin thread
needle needs to be in correct position. try threading from other side.. if in correct position.
Feb 17, 2015 | Singer 3116 Simple
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
My singer simple the needle hits the bobbin and my needle thread will not pick up my bobbin thread. what can I do?
change the needle to see if that will take care of the problem
if it doens't then the machine needs to be checked at a sewing machine shop about the timing
May 28, 2012 | Singer 3116 Simple
My threaded needle will not pick the bobbin thread??
In most cases the reason for that is the needle is not in the right way. Turn your needle around and check to make sure the bobbin case is completely inserted in the machine and it clicked in.
Mar 14, 2011 | Singer 3116 Simple
Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
Jan 24, 2010 | Singer Sewing Machines
How to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
Oct 31, 2009 | Singer 3116 Simple
Singer Pixie - trouble threading bobbin
look at the bobbin direction. if it dont pick up that way, change the direction
Jun 25, 2009 | Sewing Machines
Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Dec 29, 2008 | Singer 3116 Simple
Bobbin not picking up through the needle part of the machine
thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Oct 14, 2008 | Singer 3116 Simple
Threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
Jan 11, 2007 | Singer Drop-In Bobbin 758B-28BH Mechanical...
Singer 3116 Simple Logo
126 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
