My PAC CT90-drain it how?
My PAC CT90 doesn't have a ''hatch'' on the back of it.. ??? How do you drain it? I am in the process of taking it apart and am having trouble doing that? Any suggestions?
  • janethuffste May 30, 2010
    So it has been running now for maybe 2 hours, water coming out from underneath the bottom of the unit, same issue as last year when we tried to use it. any suggestions? Is something not hooked up correctly?
    OK... so that just means I need to figure out how to take the panels off, not as simple as I thought it would be, but I will continue to try till I get the panels off , then see if I can find what needs to be plugged. thanks for your advice!
    President:
  • 1,902 Answers
This system is set up to drain out of the back bottom all by itself, if it is not draining then simply tilt it back a little bit more so that the front is higher then the back and everything will drain just fine.
Posted on May 30, 2010
Testimonial: "Appreciate the feedback, certainly sounds like you know what you are talking about!"
  • Jeremy Reddick
    Jeremy Reddick May 30, 2010
    Water is coming out the bottom of the unit, then there is a drain plug that is missing from your unit and the drain hole needs to be pluged
  • Jeremy Reddick
    Taking the covers off is a pain, but as long as you have all the screws out it should slide back just a little then lift up.
I have a Delonghi room Unit PAC CN120E that stop cooling I have had it 5 years,
Take it apart take it outside and wash both coils with a water hose.
Oct 03, 2015 | DeLonghi Heating & Cooling
PAC CT-90 Air conditioner My CT90 is leaking
When you air condition, you essentially remove heat from the "inside air" and transfer it to the "outside air". from a google search this thing is sort of like a window air conditioner, but the hot air is sent outside via a vent hose, so the unit can be located away from the window. Any time you cool air, it holds less water, so depending on the humidity, there will be condensate formed, the question is, how is it dealt with. In window air conditioners, you see it dripping from the back side when it is running. For your unit, is it unclear how the condensate is being removed; maybe hot air going outside is directed across where the condensate collects and it is assumed it will evaporate and be vented outside as vapor? First, check and see if the unit is still under warrantee, if so, contact them and see how to get it fixed (if you mess with it, it might void the warrantee). If it has expired or the company is out of business, etc, you can try opening it up and see what is going on. The water collects under the evaporator (the fins where cold air comes out). Underneath there should be some kind of tray or something that collects the condensate and directs it somewhere in the unit for it to be gotten rid of. I'm thinking something is cracked, leaking or come loose, letting the water escape and run out. If that is the case, you might be able to use silicone seal or something like it to seal the leak. Hopefully, it is something simple like that.
Sep 13, 2013 | Heating & Cooling
I have a DeLonghi PAC-CT90 air conditioner, it works great and cools very well, however it's recently started this rattle or clicking sound that's constant and loud. It still cools wonderful, and the...
I couldn't find much online, but clicking sounds sound like relay issue
Here is a link for the owners manual if you don't have one, It wouldn't hurt to clean the filters on the unit, probably won't help the clicking problem,
http://homeappliance.manualsonline.com/manuals/mfg/delonghi/pac160.html?idRes=12778077
Aug 25, 2013 | DeLonghi Heating & Cooling
My delonghi pac ct90 is leaking water
It needs to be drained.Connect an appropriate size tubing to it, in order for it to drain where desired.
Aug 25, 2013 | Heating & Cooling
Replace Speedometer lights in 1969 Honda ct90 K-1
K1's are noted to have problems with the colored lenses falling off with age. The speed-o is not meant to be taken apart to fix this. To get these lenses back in place is a toothpick, glue and a lots of patience.
Now if it's the bulbs that need replacing that's much easier. Take head light out and slip rubber boots off each individual light and pull them out of the little tin tubes. TS
Aug 20, 2013 | Cars & Trucks
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
How do we get rid of the water that collects in
There is no container, it burns it up inside into hot air and sends the moisture out the exhaust tube which you hooked up to the back of the unit and ran either outside or underneath house through flooring. There is one of these units that does come with a bucket in the front bottom drawer that comes out, but if its a PAC ct90 just like mine, there is no water empty it handles all that itself.
Aug 04, 2009 | DeLonghi PAC T110P Portable Air...
Pinguino ct 90 trips the circuit breaker and soaks the carpet....
My Delonghi Penguino ct90 no longer blows cold air out for longer than a couple of minuets need a fix for this and it is no longer under waranty. Please help.
Jul 05, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
Empty wateron DeLonghi Pinguino Pac L 90
That probably is Ft, meaning full tank. Look on the bottom of the back side, and there should be a small "hatch" that will open. The two small hoses in there are drain hoses that can be unplugged to drain the tank. They're right at the bottom, so if you have a way to raise the unit up a little that would let you drain the water into a container. Might be a good time to clean the filter too.
Sep 08, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Open Questions:
Heating & Cooling Logo
386 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
