Question about Nokia 8250 Cellular Phone
My nokia 8250 can't power up despite a new batt and its charging perfectly.. any ideas?
    Scholar:
  • 129 Answers
Reheat cobba ic, My nokia 8250 can't power up despite a new batt - b2ffb09.png
Posted on Aug 05, 2010
Nokia 8250 can't display
try changing the battery and charge, if not charging in that case the charging socket is spoilt and you might need to service the phone.
Jul 20, 2012 | Nokia 8250 Cellular Phone
I have a Prosport 20 Plus that charged 3 new trolling batts It has worked fine for 2 yrs.I found that one batt was not charging and I replaced 3 burned out fuses.The blue,red and finally the green lites...
check the cables between the batteries, and consider changing the cables that run to and through the uncharged battery. Also make sure that the batteries are not cross connected (positive to a negative) and that there is no corrosion on posts and cable connectors. I had a similar problem.
Jul 27, 2017 | ProMariner Prosport 20 Plus Gen 2 Heavy...
My nokia 5200 has a battery charging problem.it shows its charging but the battery is still low when i remove from charging.and it gets switched off
Once i had the same problem like yours. I thought that my charger or my handphone were the problem. I borrow my friends batt, then i put it in my nokia, then it was working!! it means the problem is in my batt. I went to the service center, then they said my batt is broken. i tried to find another sources afterwards, then they said the same. I had no choice, i should buy new one. uufftt!!!
May 10, 2011 | Nokia 5200 Cellular Phone
I have an 89 yj , i just replaced altenator , battery , positive cable , ground cable, put an hei distributor on it with new plugs and wires and a solenoid and my voltmeter is in the red after about 15 run...
I would think your starter is over heating (grounding) which is draining power from batt which is making alternator use its charging capabilities to the max . starter motor is what id check. this isnt a little 14 gage wire robbing all that power so quick, it is a direct connection within the batt,starting or charging system.
Jan 11, 2011 | 1989 Jeep Wrangler
Compaq armada 110 battery not charging at all laptop works on power supply perfectly but when cable removed no charge in battery, new battery purchased same problem how can i resolve please
I'm sorry to here this but in this case you must bring the laptop in the manufacturers service center because they have to replace batt terminals for it to charge them again. It happened to my cousins laptop.
Apr 06, 2010 | Compaq Armada 110 Notebook
Nokia 6300not charging
The problem is most likely the battery itself which is worn out and needs to be replaced.
Oct 01, 2009 | Nokia 6300 Cellular Phone
Total power loss left overnight 2 bars on batt in morning no power wont charge no signs of life tried replacement batt fully charged still dead
it is definetly a hardware problem the charging pin would have got short circuited try to go to nokia care and repair it
Aug 22, 2009 | Nokia N95 Cellular Phone
Battery is not charging nokia
check batt model r it arthorised batt and check charger and batt model no
Jan 23, 2009 | Nokia 6630 Cellular Phone
Document Feeder
This sounds like a sensor failure - is it under warranty?
God bless,
Barrie Brown
Dec 07, 2007 | HP Scanjet 8250 Flatbed Scanner
Acre Aspire -- 3000 series notebook -- Power adapter issue
It's a loose connection on the motherboard. The power connector on the motherboard will need to be re-soldered. You really don't need a new motherboard. You need to find a good Technician that can do this. I use to do this at my old job. We charged $65. Some places will charge up to $90 or so.
Jun 29, 2007 | Acer Aspire 3000 Notebook
Nokia 8250 Cellular Phone Logo
199 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
