Question about Pioneer VSX-454 Receiver
Amatuer needs sub-woofer advice for Pioneer VSX-454...
I bought the Pioneer VSX-454 receiver a ways back and am now trying to get the surround sound going... I have a sub-woofer with two different bare-wire ports labeled "From Amplifier" and "To Loudspeakers" I got the fronts, center and rears going nicely, but don't know how to get the sub-woofer pumping??? How do I go from the RCA ports on the back of the reciver to the bare wire sub-woofer ports? And, I don't know if this is because I need an amp as well - and that would answer this question? I guess I always assumed this was an amp as well???
Thanks for advice,
Clueless
  • shurburt Apr 08, 2008
    So, for the A channel, would that be run from the Right or Left, or both bare wire ports? And then when it comes back, take those wires back to the A channel Right and/or Left speakers?? Is it ok to put two wires into one bare wire port?
    Sorry to dredge deeper - this is truly foriegn to me!!
  • Anonymous Mar 18, 2014
    have cerwin-vega sub woofer 100 need to hook up to a pioneer vsx-d606s
  • 4,234 Answers
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Posted on Apr 08, 2008
SOURCE:
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
Psw111 hook up to vsx-522 subwoofer
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Apr 21, 2013 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
I lost the remote to my Pioneer VSX D607S. I am trying to turn on the Sub-woofer, but the manual only shows how to do that using the remote. Is there a way to turn on the sub-woofer manually?
I dont think so as most of the sub functions are placed now on the remote control with no parallel modes on the customer panel.
The other way around is to trigger the circuit manually in the circuit but this needs care to allow the sub to switch on..
Sep 29, 2010 | Pioneer VSX-D607S Receiver
Pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Jun 21, 2009 | Pioneer VSX-D510 Receiver
I have pioneer receiver Vsx-454 i want to know if this receiver is 5.1 surrounds
Yes. It is 5.1 surround. There are 2 front channels, 1 center channel, and 2 rear channels which comprise the "5" in 5.1 surround. The pre-amp output channel for a sub is the ".5".
Jan 11, 2009 | Pioneer VSX-454 Receiver
Sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
Nov 01, 2008 | Pioneer VSX-D412 Receiver
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
485 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
