Question about Samsung RB215LASH
Freezer temperature is rising - Samsung RB215LASH
  • Samsung Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerfreezer temperature is rising - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerafreezer temperature is rising - 2_bing.gifc="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: About every two or three weeks the temperature
Defrost timer/control board is sticking...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 30, 2010
Testimonial: "Sounds right. I will check. Thanks!!"
My freezer has had ice built up on the bottom shelve for about a year now. It leaks once in awhile, what can I do?
The power cut may have damaged the compressor. If it overheated trying to restart it may just click on and off for a while. Check if the compressor is hot and running.
Jul 11, 2015 | Bosch B22CS80SNS (220 cu ft) Side by Side...
How can I Stop the bleeping on my CDA FW 381 freezer. It alarms for approx 30 seconds,but I dont think the temperature is rising. Can I isolate the alarm.
You need to use a thermometer to be sure but realize the alarm indicated a certain temperature point has reached or exceeded, not that the temperature is rising.
Try these links for additional help.
Redirect Notice
Beko CDA 565 FS Manual
Mar 02, 2015 | CDA Freezers
Temperature rising in freezer and fridge motor running constantly
The temperature in the freezer will rise if there is no air circulation. Air circulation stops when the evaporator freezes solid. When this happens the thermostat cn not respond and the fridge keeps running.
Defrost the freezer and see if things return to normal. If they do then you have an auto defrost problem.
A technician can help you with this problem
Apr 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
About every two or three weeks the temperature rises to about 15 F in the freezer. Temperature also rises in the main part.
heatman101
Oct 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer temperature changes sporadicaly. It
The temperature would charge due to change of cycles in the refrigerator operation. For example, the temperature would slowly rise if the compressor has shut off. Also, the temperature would rise significantly during the defrost process. A heater is activated at the evaporator coil to thaw the ice that forms there. This heat would transfer to the freezer unit and would cause the temperature to go up.
As long as the cycles are constant, and the temperature does not rise significantly and keep rising for a long period, there is no problem.
Oct 19, 2009 | Refrigerators
Temperature 0 The digital display switches from normal 5 to 0. Resetting works occasionally
There is likely no problem. The temperature inside a freezer will charge incrementally during the day as the refrigerator goes through various cycles. For example, during the defrost cycle, the freezer temperature will rise significantly due to the heat from the evaporator heater. This temperature rise is temporary and should not cause a problem.
Oct 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
Freezer
if the unit is a auto defrost sound like a defrosting problem, if not a self defrost and the coils are not covered in thick frost then a sealed system issue would be the problem to check
Apr 19, 2008 | Freezers
Samsung RB215LASH Logo
123 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
