Question about Sony Playstation 3 (PS3) Console
Used hdmi on another tv, wont work at home
Used hdmi on another tv, now it wont work at home with the original cable
    President:
  • 1,099 Answers
what kind of cable, is it RCA plug that wont work.
if your TV support HDMI Cable since use the cable for your connection of your PS3 console to your TV at home...
Posted on May 30, 2010
I have a pioneer xv-dv282ap home theatre and there is no audio coming out from the speakers. The only way to make it work is to use an HDMI cable using the speakers from the TV.
use rca red and white to connect to input on home theater,plug other end into tv output,now go into tv settings and find speakers and turn on external speakers,connect hdmi from home theater to tv input,you cannot record tv stations.
Jun 11, 2015 | Pioneer Audio Players & Recorders
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
My Home theater system was on with my TV. The video just went out audio is still on. I checked all my connections changed out a HDMI cable to the TV still no video only sound. Ran a HDMI straight from...
I appreciate that you did an isolation steps where the fault maybe by running a HDMI straight from your your Direct TV box.We could further steps by following mentioned below
1. Please make sure your connecting the HDMI cable on the right port
2.Please make sure you are using the HDMI cable compatible to the system.also try the supplied
cable from Bose.
3. If still does not work,please contact the manufacturer or contact the store where the item was purchased
Sep 04, 2011 | Bose Lifestyle 38 System
Just got Panasonic Home Theater and using Digital Audio cable along with HDMI cable. Cables are coneccted and when I do a speaker test all work fine. When I play my Wii the sound is coming out the Tv not...
What kind of TV do you have?
I have found one of the easiest ways to connect surround system is to connect all your accessories (ie. Wii, Cable Box, VCR, etc) to the TV.
Next find the AUDIO OUT on the TV and connect this to the TV or AUX input on the home theater.
Tune the Home theater to the Input that you connected the TV to. This should play the audio through the home theater for any input you tune the TV to.
Note: make sure to turn the TV volume all the way down otherwise there will be some distortion due to the delay between the TV and the home theater.
Good Luck,
Robert
Feb 26, 2011 | Panasonic SC-BT200 Home Theater Systems....
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
My screen wont work i tried a hdmi cable but wouldnt work what do i do?
If you can get a display with the default setup (original cords) follow this procedure:
a) Plug in BOTH the HDMI cord and the other display cords to your TV.
b) On your TV, using the disignated video input (not HDMI) you should have the main screen
c) Go to settings, and then display settings. Set up your display to read HDMI. Your screen will go dark.
d) Quickly change your TV input from video to HDMI and it should still be displayed. Save the changes.
e) Shut off the system, unplug the original cords leaving in just your HDMI cord and your designated audio cord (preferably fiber-optic).
f) Turn it back on and you should be good to go.
Dec 01, 2009 | Sony Playstation 3 (PS3) Console
LG HT502 wont recognize hdmi cable. it says hdmi
go into the video setup menu, and select HDMI set up and select "ON" that should do it
Jul 15, 2009 | LG LHY-518 System
Tv sound doesn,t work from remote ,but works on tv
Are you using an HDMI cable from your cable box to the TV? I found that the sound greatly improved and volume control was better after switched to an HDMI cable. Originally I was using component cables that were supplied by the cable company. Note: I bought my HDMI cable on line for $10. I've seen the same cable in the store for $35.
Mar 07, 2009 | LG 37LC7D 37 in. LCD HDTV
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Sony HDZ235 HDMI
use component outputs of that unit to play on tv.Or use component or video output of sony unit and connect to cable box if available and use the source switching on cable box to change sources that way you wont have to unplu HDMI cable..By the way HDMI has a new challenger in the near future called ' DISPLAY PORT' ..
Dec 03, 2007 | Sony HOME THEATER SYSTEM System
Sony Playstation 3 (PS3) Console Logo
91 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
