Question about Sony Handycam DCR-TRV22 Mini DV Digital Camcorder
PC does not see camcorder when connected via firewire port
I have windows vista home premimum on a dell 420 xps. I have tried different fire wire cables and different firewire ports to no avail. On the LCD panel, there is a flashing "DV IN". Does this indicate a bad DV port on the camcorder ?
  • Anonymous Nov 15, 2008
    I have the very same problem
Apparently I get wind from researching this issue that it's not the camera, it's not the cable, it's not your computers' hardware, that this is an issue with windows directly. I have the same camera and several other systems with 1394 (firewire) ports, and this camera used to work when I had windows xp service pack 1.
Posted on Sep 26, 2008
I have the samwe problem
Posted on Jun 04, 2008
SOURCE:
Sir when I canect my dv camcorder pc via fire wire ...but not capture video..and erorr show code 1021 ...there are no free reusorses in computer...how to solve problum...help me....thanks..
see this topic and contact the supplier .God bless you
FireWire connection to computer keeps getting dropped. Check with manufacturer to make sure you have the latest driver and firmware updates for your camera and computer. Always turn the camera's power on before making a FireWire connection. Disconnect the FireWire cable before turning the camera off. Use the camera's AC adapter when making FireWire connections. Try a different FireWire cable and try connecting the camera to a different computer. FireWire cables and ports sometimes fail.
Nov 07, 2013 | Video Cameras
I try to connect my sony CCD-TRV608 camcorder to my pc but nothing happens. Please help?
Hello, well you will find if you use Windows Vista/Win 7 no drivers for Sony cameras are loaded, none as far as I am aware are made.
But if you use Firewire cable as I do you wont need drivers, BUT make sure your camera is connected to PC via Fire Wire before you turn PC on, as it wont work if you get this wrong.
Bye
David
Jun 19, 2010 | Sony Handycam CCD-TRV608 Camcorder
DCR-HC52 fire wire port doesn't work. Have tried on several computer, none of them even see the camera. Best Buy tried using a different cable same results
This happens only mostly if you connect camera on Firewire AFTER you been PC okay, so plug your camera in the Firewire sockets then put your PC on, then the PC will open the firewire port up for use and set up a user port adrs for the port.
Jun 05, 2010 | Sony DCR-HC52 Mini DV Camcorder
Reset window vista
Dell has a program called zztop, you can find the utility here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R20457&SystemID=DIM_PNT_P03_XPS_T___&servicetag=&os=W98&osl=en&deviceid=1509&devlib=0&typecnt=0&vercnt=1&catid=&impid=&formatcnt=1&libid=7&typeid=-1&dateid=-1&formatid=-1&fileid=20307
there is a hidden partition ( you cant see it in windows nor will you be able to see it in most partition managers) that holds your original OS. Running zztop will put this image back on your comptuer.
Feb 01, 2010 | Dell XPS 420 PC Desktop
Dell XPS 420 sound software problem
Try to download a different software , Like VLC player
Jan 23, 2010 | Dell XPS 420 PC Desktop
Dell Webcam Center and Manager not showing up on my PC
Try Uninstalling them using the add or remove programs and then try reinstalling them again
Apr 05, 2009 | Dell XPS 420 PC Desktop
My canon HV20 do not connect with my dell studio 15 laptop
do yuo have an external hard drive connected...that will interfere with the connection sometimes, hdv/dv should appear in solid whilte letters unders stereo1 in the lcd on the camcorder screen, and what version of vista is it and is the firewire cable plugging directly into the pc...if it doesnt work in one port try another in different location on it.
Nov 25, 2008 | Canon VIXIA HF10 HDV Camcorder
Open Questions:
Sony Handycam DCR-TRV22 Mini DV Digital Camcorder Logo
444 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
