Question about Video Cameras
Write protected card
I have a Samsung DVD camera recorder model SC DC173U.
The2GB SD card says "Write Protect", so I cannot record anything on it, neither can I rename the videos on the card. Can you help?
You can contact me directly at tbarminc@hotmail.com
    Genius:
  • 1,447 Answers
On the SD adapter, there is a lock tap you push down usually when you put your SD card in to it, then into the USB adapter. To turn off the write protection on your SD, simply do not lock your SD in its adapter.
Look for tiny white "switch" on the side of it. When slid to the "Lock" position, your card has become "Write Protected".
Hope that helps
Posted on Apr 08, 2008
  • 4,234 Answers
Look carefully at the SD card. On one side you will find a "lock" switch. The card in question has this switch in the lock position. You can not delete an existing video because the delete function actually requires the ability to update the card which is a writing function. Flip the switch and your problem should be resolved.
Dan
  • 655 Answers
When looking at the card from the top (see pictures) there is one required notch on the right side (the side with the diagonal notched corner).
just slide the notch and use.
If still any problem just Ask me
Thanks
Iqbal
  • Iqbal Husain
    Iqbal Husain Apr 08, 2008
    and please if it works, then Accept my solution and rate it as fixya.
    Thanks
    Iqbal
My camcorder indicates there is an sd card but will not record to it
Check to make sure the type of SD. card matches what the maufacturer calls for. Also the SD card may need to be formatted before you can record to it. Check your intruction manual to find out how to format the card. One last thing to check is if the SD card is locked. Usually on one of the corners there is a sliding tab used to protect and unprotect against recording over any material that may be on the card. Hope this helps.
Jan 24, 2015 | Polaroid CAA-03040S Camcorder
When I turn on camer to record the word protection comes on . will not record i
Mini-DV tapes have a manual write-protect switch on them to prevent accidental erasure or over-recording of previous recordings. I expect this switch has been set to "save", perhaps accidentally.
Oct 25, 2010 | Samsung SC-D107 Mini DV Digital Camcorder
Cant record new video
check the memory card that you've inserted on your camcorder. tilt the protection tab of the memory card to unprotect it.
Jun 29, 2009 | Samsung SC-D372 Camcorder
I recorded a video on my samsung sc-dc 164 camcorder and i used my SD memory card instead of the disc. when i try to play my video from the SD card recording it won't play but can only hear audio from my...
how did you transfer the video from the card to your PC?
did you connect the camcorder to your PC or did you use a memory card reader?
if you can play the audio then what you need is the right video codec for the unit
try searching for video codecs through search engines
make sure that the software that you are using to play the video plays the file format of your video,
try using roxio, then connect the camcorder to your computer via USB, make sure that the drivers are installed, play the video through your camcorder then use roxio to capture it real time instead of the usual "copy-paste"
Jun 28, 2009 | Samsung SC-DC164 DVD Camcorder
Driver for Samsung DVD Camera Recorder SC DC173U
go to the samsung.com website. their support section has drivers and instructions.
Dec 11, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
I need 2 open my samsung dvd camera recorder sc-dc173u my usb port is pushed in
TAKE ALL THE LITTLE SCREWS OUT FROM THE OUTSIDE. REMEMBER WHERE THEY GO WHEN U PUT IT BACK TOGETHER.. DONT OPEN THIS UP WITH A BATTERY OR A INTERNAL BATTERY INSIDE. TAKE ALL BATTERIES OUT THEN TURN UNIT ON FOR A MINUTE TO DRAIN LEFTOVER POWER OUT. THEN OPEN UP. GOOD LUCK
Oct 27, 2008 | Samsung SCDC163 Camcorder
Problem w/my Samsung DVD Camcorder SC-DC173U
my disc are blank after recoding
Jul 02, 2008 | Video Cameras
Help!
The little lock lever on the side of the card is too long and telling the camera its inwrite protect mode try another brand of card ozdigiman
Feb 04, 2007 | Aiptek PocketT DV3300 Camcorder
Write protect turned off
If the write protection tab of the cassette is open(set to save), (STOP and Protection! will be displayed) Release the write protection tab to record
Dec 15, 2005 | Samsung SC-D353 Mini DV Digital Camcorder
Video Cameras Logo
102 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
