As you have not specified which code you need i am hereby giving how to
get all of the codes:
NETWORK UNLOCK CODE:
You
can unlock it by flashing your mobile if your mobile is a CDMA
mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA
mobile , you can get the network unlock code(NUC) by just
contacting the current network provider customer caredepartment.It is
free of cost.
Therestrictioncodecan be got from your old service
provider..This restriction code iskeptto prevent someone who stole
themobile from using it withanotherprovider...
They will have a
security check done with your date of birth etc..to verify whether you
are the exact owner of the phone..
After that they will provide
you the restriction code to unlock it and use it with another service
provider..
It is all free of cost donot pay anyone for this
seeing some advertisement over internet . That is all fake ads.
The
above proceudre works and you can verify that by seeing the rating of
an happy customer here..
http://www.fixya.com/support/t4035818-need_unlock_nokia5130c_2_use
PUK CODE:
PUK
code can be given only by your service provider which is specific for
each and every mobile number.
Contact
your sim customer care department over phone. Its free of cost
to get the pin or puk no. If you cant contact through your phone get
some other phone and contact them.
Go
to the nearest service outlet of your service provider they can also
help you.
There is no other go than the
above procedure only your service provider cangive it nobody else in
this world nor any software.
Go
to the below link and you can confirm that the above procedure works
and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
PIN CODE:
HI
If you are asking for pin contact your service provider , he will give
you a default pin .
If
you try pin more than few predefined no of times your phone will ask
PUK code which can also be given only by your service provider which is
specific for each and every mobile number . Do not try PUK(new pin code)
code many times or else your sim will be blocked and you will need a
new sim.
Contact your sim
customer care department over phone. Its free of cost to get the
pin or puk no.
Go to the nearest service
outlet of your service provider they can also help you.
There
is no other go than the above procedure only your service provider can
give it nobody else in this world nor any software.
SOURCE: nokia 6230i security code
hi
Default code for Nokias is 12345. This will work if you did not change access code.
If you set up your own access code, you can recover the code by connecting to computer or using a file manager. You can download Fileman here.
After installing file manager check the folder C:Systemmmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
Here is also a reset procedure that works on some Nokia, I do not know if it is good for 6300.
Beware, by using reset below you will delete all data stored in phone memory, even phone numbers if they are stored in phone memory:
Take the SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on.
Keep this two buttons pressed until the reset screen appears.
Wait some time to reset.
Switch phone back on.
By Mr.GINKO plz do rate this post
SOURCE: restriction code nokia 6230i
Hi Friend,
It is paid service and many providers give it. U may search them here at fixya or other mobile supportforum like GSMHOSTING, GSMHELP etc. No one can give u such code because it is part of Nokia security. The code is as per cell'sunique IMEI and only can be obtained by professional software toolslike BB5 box and other compitable tools. It is advisable to visitnearby mobile technician who have such box. He will charge u forthat. If it sounds informative do not forget to vote.
Network providers lock handsets to their networks in order to protectthe investment they made as you have received the handset at a reducedprice. Therefore the only people that are able to unlock the handsetfrom the network are the network providers.
Ifyou need a restriction code you will need to contact your networkprovider, these are the people who hold this information. They shouldbe able to give you this information.
Thanks for using Fixya
Regards,
Ayyasam
SOURCE: unlock Nokia 6230i
U get the unlocking code from http://www.unlock-free.com/nokia-master/nokia-6230i.html .It's useful for you.
