Question about Clarion APX400.4M Car Audio Amplifier
NO Audio from speakers?
I have a Clarion Marine CD Radio (XMD3) connected to a Clarion APX400.4M Amp. (on Boat) and cannot get any sound out of the speakers. Have power to both units and both seem to be working except for the audio. I have checked the two fuses behind radio, the 40 amp fuse in the amp itself and the two fuses at the battery connection - all good. Have checked connections at speakers and all seem to be good. After winter and getting boat back from shop for summer-zing boat noticed one of the wires of the rear remote broken off, repaired and reinstalled and seems to be working, all buttons function on both remotes and seem to control radio fine but no sound. This is the first time I did not re-install the battery myself as it was re-installed at the shop. Thanks in advance for any help.
KaeZoo
  • 156 Answers
SOURCE: 400 watt amplifier not working
Disconnect all the speaker wires from the amplifier that runs the 6-speaker system. Switch off the amplifier or disconnect the remote turn-on wire, then re-connect it. Does the power light still flash with no speakers connected? If so, your amplifier is probably damaged. If not, then connect one speaker and see if it plays. If it doesn't, disconnect the first speaker and connect a different one. If the first speaker plays, continue connecting the rest of the speakers until you find the one that's causing the problem.
Posted on Mar 07, 2007
  • 631 Answers
SOURCE: Sea ray boat Clarion stereo and amp
Unless a fuse is blown, there's a problem with the wiring or you have a defective component, there's no reason the amp shouldn't come on. You need to confirn that you have the proper voltage at the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on May 23, 2008
SOURCE: NO SOUND FROM CLARION XMD3
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
Posted on Jul 08, 2008
  • 3 Answers
SOURCE: Clarion M5675 won't turn on
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Posted on Apr 19, 2009
  • 3 Answers
SOURCE: radio works on tech bench, not in the boat
Yes, the yellow wire is the switched hot lead - it is typically connected in one way or another to the ignition switch. There is also a smaller gauge red wire that is connected directly to the battery (through a fuse of course). Both of these wires have to have power for the radio to work. Also the black wire has to be connected to a good ground. If all three of these wires are confirmed to be in good order (power where there should be power, ground where there should be ground and no shorts) the radio should at least power up when they are all hooked up and the ignition is on.
Posted on Jun 25, 2009
I have a Clarion Marine XMD3 radio in my boat. There is a set of speakers in the back of the boat and a set in the cabin below deck. The set in the below deck cabin work fine. The set in the back of the...
Look for loose or broken wiring connections. Swap front and rear speakers wires at radio and determine if problem is the radio or the speaker system.
Aug 01, 2013 | Car Audio & Video
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
XMD3 I bought a second hand boat with this radio , not working , do you have an installation schema ?Thanks
hello there ,firstly at the rear of the radio you will see two plastic blocks top block is your power in )secondly bottom block is your( audio ) sound these wires are colour coded for front and rear speakers ,your dc power which cannot be over 13.8v black and red wire on top block you have a socket to the right this will be for the antenna ,also check the fuse line before switching on hope this helps you
goodluck
Mar 25, 2011 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
CD doesn't eject CLARION XMD3 marine radio
Disconnect the fuse of radio and reconnect it again.
That should force him to eject the CD
Oct 27, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
No ipod connection
I am not sure that you will be able to power the iPod through the sound system. Could you not run a nearby 12VDC plug for power without it looking bad or getting in the way?
This seems more of an iPod issue rather than a Clarion issue. You may be able to get a solution from the iPod Support community with a Google search for iPod Support.
I trust this information proves beneficial.
May 15, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
CLARION MARINE SPEAKERS CONE DETERIORATED
of course, the only problem is finding someone to do it, and is the speaker really that nice and worth the money
Mar 21, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Oct 19, 2007 | Clarion XMD3
Clarion APX400.4M Car Audio Amplifier Logo
217 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
