Question about Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas
We have a laars lite 2, when we openned the pool
We have a laars lite 2, when we opened the pool for the summer the following took place. Turned on the gas, set heat to high and heater on. The pilot would come on, the gas started flowing, the heater kicked on and ran for 3-5 seconds and then shut down. The cycle will repeat itself but we can't get the heater to keep running. The pressure switch? (the thing that hangs down from a coiled copper line with two wires coming out the bottom) is very hot.
    President:
  • Teledyne Laars Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It could be...does it open up at the point the heater shuts down? Check it with a DMM to see. It is more likely an issue with flame recognition off the pilot/ignitor. Check them for rust that would cause a faulty connection.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on May 30, 2010
Pool heater will not stay lit
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Apr 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a propane laars lite 2. The pilot is on but the gas valve will not open
is the tank a least 35 % full check for all the valves if not two solution replace ignition control or gas valve very hard to guess over this
Sep 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars lite 2, mod-lg125n, sn. d03pj3400.
sounds like heat exch is plugged.remove top of unit and inspect for nests.could also be plugged with soot because of poor burner flame characteristics.with top off,turn htr on and look straight down into unit. you should be able to clearly see burner flames between fins. if not remove exchanger and clean
Jun 07, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Water is running out the gas pool heater
Hi could be a spilt heat exchanger did you drain all the water out of it
May 23, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite 2 - Turns off after 5mins of being on!
This happened to me and the tech came out and change the pressure switch and it worked fine afterwards
Jun 15, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Natural Gas  Logo
263 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
