Question about Kodak EasyShare V1003 Digital Camera
Unloading pics easyshare v1003
I can't seem to unload pics just by linking to usb, what else must I do???
  • 2 more comments
  • hachit Apr 21, 2008
    How to load pictures from camera to computer
  • Anonymous May 25, 2008
    after taking still pics and a video on the same camara, I cant down load all of them on the computer, I get a message half way thru saying something about a problem.
  • theresa pyskaty Jun 07, 2008
    can't transfer pictures to computer.....i am connected to usb port and camera.
    also how can i purchase a memory card, didn't realize only 9 pictures
    connected to usb port and camera can;t transfer pictures to computer
    also, how do i purchase memory for pictures....didn't realize picture only snaps 8 shots
    Sniper:
  • 58 Answers
First - check physical connection:
when the camera is connected to the computer through usb, the camera should be turned on, nothing will appear on the screen and you will see a flashing light from the camera signifying that it's "making a connection"
if, the camera screen is active while connected to pc, that means it's not making connection so check other USB port, like the back -it's more reliable as it's directly connected to the motherboard, not a hub like that of the one in the front of the tower
when it's showing a flashing light, check if the computer shows an "image transfer window" - that will appear if you are using Kodak Easyshare Software, if you don't have it installed, check if WIA (Windows Imaging Acquisition) transfer options will automatically pop up
If not please check this
rightclick on My Computer> properties> Hardware> device manager
1. check if the cam is a subcategory of the Universal Serial Bus Controllers -
a. IF IT IS, highlight it, rightclick and select Update Driver, select bottom options until it asks you to choose between "Kodak Camera" and "Digital Still Camera", select "Digital Still Camera"
now it will update then check if it would appear under "Imaging Devices" (if you have XP) or "Portable Devices" (if you have Vista)
a transfer window should appear using WIA, then follow prompts
a.1 if it created it's own category under Device Manager, open my computer, select your camera and it will act like a removable disk, so you can copy and paste pics
b. IF IT IS NOT, please check if it's under a Kodak Category (open my computer, select your camera and it will act like a removable disk, so you can copy and paste pics) or Imaging Devices/Portable Devices, righclick on your cam model or kodak camera> update driver, select bottom options and at the part where it asks you to choose bet the kodak cam and digital still, please select the Kodak Cam, then an Eeasyshare Software Transfer Window should appear (that's if you have Easyshare Software)
you can dl it from www.kodak.com/go/easysharesw
Posted on Apr 30, 2008
    Guru:
  • 1,463 Answers
Did you get any cd's software with the camera ?
riz.
Posted on Apr 08, 2008
  • 106 Answers
1. INSTALL THE CD PROVIDED WITH THE DIGICAM ON PC...EASYSHARE...AND THEN CONNECT THE CAMERA TO PC IN CONNECT MODE...IT WILL ASK U TO COPY THE PICTURE ON PC.
2. RIGHT CLICK ON THE REMOVABLE DRIVE WHICH IS SHOWN AFTER U PLUG THE CAMERA IN USB.....U WILL SEE FOLDERS INSIDE THE THAT DRIVE...DUBBLE CLICK THAT AND U WILL SEE THE PICS INSIDE...COPY IT AND PASTE IT ON PC IN THE FOLDER OF YOUR CHOISE
Want to know what the black Knob, I think called unloader valve is used
Hubert, The unloader valve is like a by pass for the water and regulates/controls water pressure and redirects water when gun trigger is released. Check the attached links,instruction and guides to learn more about Pumps/unloader, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Washer Unloader Valve
How to replace an unloader valve on your pressure washer pump
All About Unloader Valves ePowerWash
How to Replace an Unloader Valve on Pressure Washer Repair Guide Help...
May 17, 2016 | Garden
I bought a usb adapter for my samsung s730 but i need a program to unload the pics?
may u need a driver instead. pics can tranfer anytime in the computer via copying and pasting it. other wise there is alot of software u can find in the internet
May 30, 2011 | Samsung Digimax S730 Digital Camera
Can't upload photo's to computer . The Camera does not unload the current shots I took. The computer informs me there is no pictures on the camera, but when I press review on the Camera it shows a number...
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 03, 2010 | Kodak EasyShare V1003 Digital Camera
Downloading pics fr9om camera
plug it onto computer as a usb device and use driver CD if computer wants. you need to see as a drive on my computer. and then click on it.
Oct 12, 2009 | Kodak EasyShare V1003 Digital Camera
I have a pressure washer with a faip 3 piston pump. the other day i was using it and it stopped unloading. i cleaned the unloader and it didn't help. I bought a new one and it still won't work. I e-mailed...
I think your main problem is that the unloader valve needs to be lubricated. Use the very best water resistant bearing grease you can find. If you can e-mail me a pic of your unloader assembly I can try to explain how to set it up. firehead@roges.com
Sep 14, 2009 | Honda Garden
I have a sticking unloader valve in my Karcher 3050. where is it and how do I fix it?
Hello:
Here is a schematic. On page 2.1, part #1 is the unloader valve. You need to remove it and lube it with a very good waterproof grease. Also insure the O-rings are in good shape and the spring action is working.
Jul 07, 2009 | Karcher G 3050 OHR Gas Pressure Washer
I lost everything when I moved
I have a Kodak EasyShare v1003 ... but no install disc, and I have a new computer .... Plz. help I really would love to upload my pic's to my computer and change info.on my Kodak . Thank You
May 02, 2009 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare C613 turns off when connected to PC
The camera is supposed to go blank when connected to computer.
I hit the "share" button and can then download photos, even though screen is still blank.
Feb 25, 2009 | Kodak EasyShare C613 Digital Camera
Unloading Camera
do you have the kodak easyshare program? it cam with your camera. do you have a usb cable? if not buy a card reader. you can find them at any wal-mart and they are under 15$
Dec 05, 2008 | Kodak Easyshare M753 Digital Camera
OLYMPUS FE-240 digital camara can't use port to unload photos
You better take a closer look. I know my friend Dave always looks in the wrong place. Here is a link to you manual
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1284
Radio Shack has cables of all sorts if you've lost on but it sounds like you just need a map and some magnification.
Paulpsps@aol.com
Nov 07, 2007 | Olympus FE-240 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
116 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
