Question about Westinghouse Washing Machines
I have a westinghouse washing machine LT955S the agitator washes the clothes fine, but when it finishes draining it clicks then flashes PU in the display and doesn't spin. I have checked for blockages and found none. Do you know what might be my problem?
  • 5 Answers
SOURCE: have a westinghouse washer LT955s
I have had great luck with repairclinic.com. they will help diagnose and let you know what part you need and have them in stock. Also try Fox appliances, they have a great network and broad parts selection.
Posted on Jul 09, 2008
  • 1028 Answers
SOURCE: washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Posted on Sep 13, 2008
  • 7 Answers
SOURCE: washer doesn,t spin
two possibles here, if the drain pump is clogged and therefore the unit will not go into a spin. After pumping, it will error out and just shut off. If the pump is ok, then the motor control unit has failed.
Posted on Oct 28, 2008
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Posted on Apr 15, 2009
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
Will not agitate
check the module that controls the agitation of the motor. It is found in the control panel and if it fails the motor has no agitation action. have a washing machine check it out.
Jul 14, 2013 | Admiral AW22 Top Load Washer
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
White-Westinghouse wash cycle not engaging
Likely transmission failure. The motor controls agitation as well as draining
Feb 26, 2013 | Washing Machines
My Westinghouse lt908s washing machine has started bundling clothes up and knocking sides of machine. Even after opening lid and redistributing load evenly it keeps spinning then bundles up load and knocks...
May be a problem with agitator gear box,open on wash cycle and use screwdriver to by pass cut off switch by pushing screwdriver down on little switch that is located where tab on lid is.If agitator is traveling at too much of a rotation that may be cause,also agitator mat be lose if you can grab and move up and down.Then remove cap on top of agitator and tighten bolt,if lose if not agitator may need to be replaced!
Jun 12, 2011 | Westinghouse Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
Roper washer will not agitate
could be the transmission or the drive motor to transmission coupling. You say the agitator doesn't work but it washes fine please clarify your problem.
Jan 12, 2009 | Roper RAS8445KQ Top Load Washer
Washer won't spin
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
102 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Robert Siegel
Level 1 Expert
Steven Clarke
Steven Clarke
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
