Question about Canon CanoScan LiDE 30 Flatbed Scanner
Scanner not detected in win fax windows 7 this recognised in hardware devices and working properly
    Problem Solver:
  • 5 Answers
  • 516 Answers
Mercury Ez View TV Tuner Card Driver for win 64 bit
You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
If your device was working on a USB2 port, it also should work on an USB3 port, on the same computer. But don't expect another speed, because the slowest part decides the speed.
Oct 17, 2014 | Microsoft Computers & Internet
Computer does not recognise Scanner -- why not?
How old is the scanner? did you read for what Windows version it was made in the first place?
If it is for an older OS then Windows7 and you are using Windows 7 or higher, you ran out of luck.
Always first install the software that came with the device. The driver needed for the device is supposed to be on the install disk.
Oct 17, 2014 | Veho VFS-008 Smartfix Film Scanner USB...
Scan note working (Hp Laserjet M5035 MFP)
Lets check whether windows detects your scanner
Right click My Computer > Manage > Device Manager
Under Device Manager check Imaging Devices
If there Double click Imaging Devices and check the device under that. If you find your scanner there .Then the scanner is installed properly
Now Lets try a test scan
If Windows Xp do this .
Click start > Run > Type wiaacmgr.exe press enter key
Now take a test scan
If your windows is vista / win 7 then
click start > All programs > accessories > Run
on Run window > Type wiaacmgr.exe press enter key
Hope this would work
Please rate me if you are satisfied with my answer
Mar 20, 2011 | HP LaserJet M5035 MFP Printer
Micorsoft Windows Fax and Scan has stopped working. > A problem caused the program to stop working correctly. Windows will close > the program and notify you if a solution is...
If if was working properly in the past, the problem is usually due to the device (your scanner, fax or camera) has somehow come unplugged from it's USB connector and Windows no longer "sees" the device. Try powering OFF the unit, unplug your USB cable from it. then power OFF your computer. Now, power ON your computer, log into Windows. Next, plug your scanner/fax/camera into an available USB port. WATCH to see if Windows detects the device. IF it does, attempt to scan an item... it should start the Scan/Fax wizard.
IF it does NOT recognize the unit or start the wizard, I would look to remove the device from Device Manager and try again.
Mar 09, 2011 | Computers & Internet
I have connected my 4Gb Usb Device to my PC, But
insert the usb drive
if a notification bubble appears click it
a dialog box appears showing the new hardware found
click on the detect automatically button.
it starts searching..
if the driver is in r system it installs
if not download the driver from net
write the device model number and company
check ur usb port......
try using in ur friends computer
Mar 11, 2010 | HHP ImageTeam 4710 Barcode Scanner
Windows 7 Fax problem
Here is a couple of links ... okay, scratch that. Here are a whole slew of links that might help you with your problem.
http://www.alltheinternet.com/texis/open/search?q=Windows+7+fax+drivers&ref=04172017232732&p=
Apr 18, 2017 | Computers & Internet
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
Epson Perfection 1200 Scanner Driver Needed for Windows 7
I posted this for another user but i'll post it here too,
I remember looking for hours for a driver for my Epson 1200 scanner back when I upgraded by dad to Vista 64 Bit, eventually I found one. Just today I upgraded him to Windows 7 64 bit and remembered I couldn't get it to work, luckily I was able to dig up the driver I used for Vista 64. Worked great in Windows 7.
I can't remember where I found it so I can't credit the person who made the driver unfortunately, however i've uploaded it to Rapidshare for you to download. Here is the link:
http://rapidshare.com/files/324940248/epsonScan_1.0_Per1200Win64eu.zip.html
Just open up the zip file and run the setup. :)
Hope this helps, Merry Christmas!
Dec 16, 2009 | Epson Perfection 1200 Photo Flatbed...
Error message on Canon scanner -there is a twain error, device might not be connected. I am using Windows 7 Home Premium recently upgraded from Vista Home Premium. What do I need to do to be able to use...
Was it all working OK before you upgraded from VISTA? If yes this sounds like a driver problem. Visit the cannon site and download their latest drivers for Win 7 - that is if there are any yet. As an early adoptor of Win 7 you can expect to have issues with hardware drivers where manufacturers have not yet developed them for Win 7. Once Win 7 has been out and about for 12 to 18 months most manufactures will have caught up and issued new drivers.
Nov 18, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon CanoScan LiDE 30 Flatbed Scanner Logo
357 people viewed this question
old marine
old marine
