Question about Acer 91.63X07.001 Keyboard
Where is the Fn key an a dell keyboard? - Acer 91.63X07.001 Keyboard
  • 516 Answers
This is a simple problem, due to the size of laptops, the manufacturers cannot fit on a normal number pad as on a standard keyboard, so what they do is use a function key to turn a portion of the keyboard in to the number pad.
to get rid of this you need turn the 'number lock' off this may be a single key or a combination.
for my laptop its:
press together; the function key (normally 'Fn' bottom left) and the number lock key (Num Lock).
hope this sorts out the problem.
Posted on May 30, 2010
What's the FN key and where is it on my Dell Inspirion 570 desktop computer?
There is typically no FN key on a desktop PC keyboard if it is full size. The Dell website does not show FN keys on their standard keyboards for desktops. A mini keyboard would have one however. You can buy a mini keyboard for your PC, which has a FN key:
http://news.techgenie.com/latest/btc-5100c-mini-keyboard/
Mar 04, 2016 | Dell Computers & Internet
I can't turn the fn key off
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it.
Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
Feb 06, 2013 | Dell Inspiron 1501 Notebook
I can't activate the bluetooth because there is no FN key on my keyboard. It says to activate the bluetooth to press FN+F2. There is no FN key on this keyboard. Is there a way around this?
Hi ,
You need to look for a key tthat says FN, should be on the bottom left , of the keyboard , you must have one , if not tell me your computer make and model , and I will advise futher .......Good luck Roy
Oct 01, 2011 | Dell Inspiron 530s Desktop Computer
HOW TO DEACTIVATE TEH Fn KEY IN DELL LAPTOP
Hi names Rui, to turn Fn in you dell you need to:
1. Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key.
2. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens.
3. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it. So i hope this will help you.
Jul 20, 2011 | Dell Vostro 1510 Laptop
My Dell laptop keyboard settings have apparently been changed-I have to hold down the Fn key to get the letters on the keyboard instead of the Fn items indicated on the keyboard. How do I fix it?
Maybe this is the result of inadvertently turning on "Sticky keys" (see the Accessibility Control Panel Help file). Try holding the Fn key down for several seconds with no other key pressed to see if that turns off the Fn lock-on. After that you can disable the Sticky Keys function in Accessibility.
Feb 09, 2011 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
I would like a manual for the latitude D610 keyboard to know how to use the symbol that are highlighted in bleu
In the lower left hand corner of your Dell Keyboard -- you will see a Blue Key labeled -- "Fn". This key allows you the use of ALL of the other blue labeled keys on your keyboard. You must press the FN key and the other "blue" key at the same time for them to work.
The keys on the right side of the keyboard with the blue numbers on them are controlled by the Numlock key and Fn key. The light at the top of the keyboard near the power button, with the number "9" inside a picture of a lock, will be lit if the Numlock is enabled.
You may need to press the Fn key to type numbers even if the Numlock is turned on. There is a setting in the BIOS called Enable Keypad and if you set it to By Numlock you will not have to hold down this key to type a number.
If you are still having trouble with these keys, please see the general keyboard troubleshooting guide
http://ftp1.us.dell.com/diags/R65848.htm#Key not responding or typing wrong character
Jan 13, 2010 | Dell Latitude D610 Laptop Computer -...
My speakers do not work
The Dell has a "Fn" key. The "Fn" used with other keys control special features. I have a Dell keyboard here, on it holding the "Fn" and pressing "End" will alternately mute/unmute the speakers. "Fn" + "Page up" will raise volume, "Fn" + "Page down" will lower. You may have the volume muted, or turned all the way down.
The keyboard I have is from an 1100, your "Fn" key combinations may vary from mine.
Jan 02, 2009 | Dell Latitude D600 Notebook
Fn key on keyboard seemed stuck
hit shift and "Num Lk" at the same time. Num Lk is abov the F11 button on some Dell keyboards.
Tony Nguyen From Pasadena, CA
www.connectionzpcrepair.com
Aug 06, 2008 | Dell Latitude CPX Notebook
Keyboard
Hi, you can usually brighten most models of laptops by using FN key + (one of the F1-F12 Keys or (FN + Arrow Keys.) Hope this helps John
Feb 20, 2007 | Dell Inspiron 3000 and 3200 Series Laptop...
Acer 91.63X07.001 Keyboard Logo
172 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
