Question about HP iPAQ hw6515 Pocket PC
Mobile fails to start while loading config.txt. The phone just switches off.
I tried charging my mobile after 15 hrs through my USB Cradle. After a while, the mobile switches on and prompts for Screen Alignment and other test parameters and asks for Time configuration. Later the mobile displays "Loading Config.txt" and at 40% loading the mobile shuts off and will go dead. This repeats every 10 mins and I am unable to switch on my mobile. Can someone help me how to resolve this issue. Note: I have not taken any backup yet..!!!
Shiv
Download HP Universal Bootloader and reinstall the OS. I did it. It works fine.
Posted on May 19, 2008
Nokia E71 power on / off issue
i think that you might have not properly charged your batterry before first use it is being noted that all mobile manufacture recommends at least 10- 15 hrs of continus charging of the battery with the phone swtiched off is needed to work effectively in the future if you do so life of the battery will incress and you can incresse the back up of the battery and it is proven also so charge the battery well and try and remeber only recharge the battery agin when a battery low signal is shown
these are some tips :
Dont talk or use mobile phone when the phone is charging its battery,
Only Charge your mobile when it shows " LOW BATTERY ",
dont use mobile if any water particals get inside the phone ,
use only orginal battery ,
Dont over charge your mobile,
Use the mobile to talk only when the network signal is high else use sms facility to communicate,
Change the mobile battery as soon as possible if it damaged,
Use only original charger to charge the battery,
when you try to remove battery make sure that the phone off,
if the phone is not using in long time remove battery and keep it safe,
Dispose the battery safely if its life is over
Oct 20, 2009 | Nokia E71 Smartphone
Phone won't charge or turn on
it seems you have not charged your cell for initial 24 hrs and used the mobile as per the policy of every mobile company. Anyway, switch off your mobile and keep it on charging for next 24 hrs. In case it doesnot works after that also, go for replacement with the vendor.
Jun 15, 2009 | Sanyo Katana Eclipse X Cell Phone
Mobile phone does not power up
output pin connection may be failed...service the mobile
Jun 06, 2009 | BargainCell AT&T HTC 8925 Tilt Smartphone...
Mobile startup failed . contact the retailer
hi,
Your phone's memory card must be infected with virus or has some fault. Please remove the memory card and try to start the phone again. If it goes through, please back up the data in your memory card and format it. In most cases, this procedure solves the "Phone start up failed. Contact the retailer" error.
I'd advice you to format your phones internal memory as well, it will flush out any errors present. save your "phonebook" data somewhere and Make sure your phone's battery is fully charged if not plug the charger in and proceed. NB: interrupting this process might render your phone useless. So, be careful.
To format press *#7370# it will prompt you for security code, enter it and the phone will reboot. Your phone will be reset to "factory settings."
Jan 13, 2009 | Nokia 6600
Display problem
Hi there
Thanks for posting your problem on fixya
This problem is cause of the game because nokia and sony ericsion they both has his own mobile and technologies. Sony ericsion games are conflict to your nokia moblie. Please remove all the games from your nokia moblie. charge you mobile full. switched off and then off. its working fine
Is this solution helps you then please vote for me
Thanks
Robert
Aug 05, 2008 | Nokia 6270 Cellular Phone
Restore factory settings
hi,
The default security code for Nokia is 12345.
You can recover the password. The best way is to download a file manager to your phone. I use Best Fileman for my N70, from http://www.smartphoneware.com/ It’s for series 60and 40. The trial version should be enough.
In the file manager (when installed on your phone) you’ll find under- C:\System\mmcstore -the file you’re looking for, you have to rename the file- mmcstore.txt -then send it to another mobile (best way) or your PC via luetooth or USB, open it on the other phone and your password will be revealed.
Rename that file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card.IF you reset (format) your phone you will lose all the data stored on it. Resetting sometimes gives negative results. You can reset it through your menu, if you can switch the phone on of course.
Using the reset code is not recommended so keep it the last choice.
Try this for hard frmat:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
THANK YOU!!..
Jun 28, 2008 | Nokia 6300 Cellular Phone
Mobile phone been charged
hi
these usually have a number you can text stop to.
usally the same number that sends the messages, have you tried the web site see if they have a number to stop the texts ?
riz.
Jun 04, 2008 | Nokia 6280 Cellular Phone
T-mobile phone Not Charging
to where are you connecting the charger?
how old is the charger? maybe the cable its broken in the inside... this usually happens at the ends of the cables or if there is a little bump somewhere..
try connecting them and play with them by moving them a little at the ends.... so there will be better a contact..
Dec 11, 2007 | T-Mobile Sidekick® 3 Cellular Phone
HP iPAQ hw6515 Pocket PC Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
