Question about GE 24-7/8" Convertible Portable Dishwasher - White-on-White
The inner gasket came out of the unicouple for the sink. How do I put the gasket back into the unicouple?
Why does my locking collar from my unicouple hose not fit on my kitchen sink faucet/
Go to a plumbing store where the contractors
go & get the correct adaptor
Sep 28, 2014 | Plumbing
'Dishwasher' doesn't wash dishes. My dishes come out with grains of 'dirt' on them. I've stopped using the dishwasher, and it's become the drying rack for the dishes that I wash myself. Any clue on how to...
Usually this is due to a partially blocked drain. Most of the time the problem is either at the sink / garbage disposal connection or the Air-Gap is blocked near your sink. The air gap sticks up above the sink about 2.5 inches. You lift off the cover, unscrew the inner plastic nut NOTING the installed position of the upper / inner U cap and lift off the cap. There may be food particulate in there. Clean it out and put it back together. If you found nothing there then remove the hose from your under sink connection and clean the hole out that the hose connects to.
If you do all of the above and the problem persists just repsond here and we can continue troubleshooting.
Thanks for choosing FixYa.
Kelly
Sep 08, 2010 | Dishwashers
Is there a part that attaches the unicouple to to
yes there is a common part you can pick up at any hardware store. just replace this adapter with your sink airiator.
Mar 01, 2010 | Dishwashers
How do I replace the door gasket on a Westinghouse front loading washing machine? Have taken off the front steel ring that holds the gasket in place, but looks like I need to take the front panel off the...
The step by step procedure to replace the head gasket are:
  1. Open door and pull on inside of gasket to expose screws or 1/4 nuts.
  2. Loosen[do NOT remove] all screws and pull old gasket out.
  3. Place new gasket in sink of hot water to soften it and put back around door.
  4. Snug up a couple of screws on each side and test seal by shutting door.
  5. You may need to adjust inner panel until just right..then tighten all screws
Sep 23, 2009 | Westinghouse Washing Machines
I needs to replace my refrigator door gasket. I need a manual with pictorial diagram and with details on how to remove and install the gasket.
open door and pull on inside of gasket to expose screws or 1/4 nuts.. loosen[do NOT remove] all screws and pull old gasket out. place new gasket in sink of hot water to soften it and put back around door. snug up a couple of screws on each side and test seal by shutting door..you may need to adjust inner panel until just right..then tighten all screws
Sep 05, 2009 | Refrigerators
Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Faucet connector for an old Kenmore portable dishwasher
Here is the part you need to fix the unicoupler: http://www.repairclinic.com/SSPartDetail.aspx?s=t-612568-%3d%3di612568&PartID=612568 The ring didn't fit on mine, so I just used the old one. Pull back the old ring, pry off the c-spring with your nails, and replace the coil spring, teeth, ring, and c-spring.
Nov 11, 2008 | Dishwashers
Repairing the unicouple
I ordered it from a local appliance repair shop. It is a unic.repair kit and has the following numbers on the package. B21902X/1 and WD35M27 It cost about $25 CDN.
Sep 12, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE 24-7/8" Convertible Portable Dishwasher - White-on-White Logo
145 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
