Question about Nikon D70s Digital Camera
Program "P" function is not working. all images are over exposed
    Brigadier General:
  • 11,967 Answers
Did you set your "exposure compensation" to a higher setting than "0"?
Posted on May 31, 2010
Why does my Coolpix overexpose images when zoomed in?
If you zoom in then press the shutter down halfway. If you zoom with the shutter pressed half way you can get an over exposed image.
Aug 04, 2014 | Nikon Coolpix 4300 Digital Camera
PICTURES ARE BLACK
6 Ways To Fix Too Bright and Too Dark Photos
Recompose The Photo This is probably the simplest solution. When taking a photo of a scene with very bright and very dark parts, move your camera to eliminate one of the extremes. In the case of the band, I would have either closed the curtains for the shot, or recomposed completely and photographed from the window looking at the band, and the crowd behind.
Use Exposure Lock If you can't recompose the photograph, instead tell the camera what part of the image you would like to see. The rest of the photo will be either over or under exposed (too bright or too dark) but at least you will see your subject. You can dothis by placing the center of the image at your subject; half depressing the shutter to lock the focus and exposure; move the camera to re-compose the image; and fully depressing the shutter.
In the band image, the camera chose to correctly expose the scene outside, but even if the band member had been correctly exposed, the window would have ended up being over exposed and you would just have seen white.
Some cameras have an option called 'spot metering' to set the part of the image you'd like to be correctly exposed. If your camera has this setting, enable it before using the technique above.
Use Fill In Flash If your scene has a sunny background, but your subject is in the shade (or has a hat on), turn on the flash (as I explained way back in tip number 9 - Using Flash During The Day). I know it seems wrong but it really does work! By using the flash, your subject will look as bright as the background. This would have worked well for the child shot above.
High Dynamic Range Imaging This technique is not for the faintof hearted. It requires a subject that does not move; a good camera with the capability to set the exposure and output RAW images. A tripod and image editing software like Photoshop CS3 are also needed.
High Dynamic Range Imaging (or HDR for short) is a technique for placing both very dark and very light areas in the same photo. It requires you to take a number of photographs of thesame scene - each with a different exposure. First take the shot using the camera's recommended settings. Then, in manual mode and keeping the aperture at the same value as the first shot, take a sequence of shots - each shot having a different shutter speed (above and below the original). You'll have 5-9 shots of the same scene all in different exposures.
Merging the three images to the left creates the HDR image below. Thanks to Photomatix for the images.
hdrmerged.jpgNow import these into your favorite paint program. I use Photoshop, but you can as easily use a cheaper program designed specifically for HDR photos like Photomatix. Follow the HDR directions and the paint program will merge these images into one great looking shot!
Use a Filter If your scene is of a brightsky and a dark ground (for instance at sunset, or on a cloudy day), you can use a graduated neutral density filter. This filter cuts out someof the light from one part of the photo (the sky). This will correctly expose the ground and the sky without needing to use HDR. These filterscan be complex to setup, so I don't usually recommend them for beginners.
Fix The Original Photo in an Image Editing Program twobright2.jpgFinally, if you can't take another shot at the same location, you can fix the original image by changing the levels using a paint program. This works best when your subject is darker than the rest of the photo (because cameras lose detail in over-bright areas). I've brightened the band member in the top image using this technique and while it looks okay in thissmall shot, this technique can tend to amplify any noise in the image. The darker the subject, the harder time you will have fixing the image.
I discuss exactly how to use this technique in lesson 2 of my free Image Editing Secrets course. I have a tutorial for Photoshop, Photoshop Elements, Paint Shop Pro and the free Google Picassa.
- See more at: http://www.digital-photo-secrets.com/tip/140/6-ways-to-fix-too-bright-and-too-dark-photos/#sthash.58eENOTt.dpuf
Jul 09, 2014 | Nikon D3000 Digital Camera
Mfc 9320 cw is is printing leaving white lines and low quality images with new cartridges and new drums
If you replaced the drums and the cartridges and still get white lines it means there is something obstructing the imager. I believe this printer has LED imagers, In the printing process areas that are exposed to the light are printed as black on the paper and areas that are not exposed are left white. I would look for some dirt or debris on the scanners or some LED are faulty. If it has a laser scanner there may be dirt on a mirror
Jun 11, 2014 | Office Equipment & Supplies
Intova ic12 buttons wont work
Hello josh Rosefksy,
This sounds like your IC12 is defective. Please contact Intova via email, fatema@intova.net or call us at 808-837-0074 for customer service. Thanks
Sep 01, 2012 | Intova Ic12 Digital Camera
Over exposing
You should carefully review the settings especially the Mode and Function settings (Func/Set button). The Exposure Compensation, White Balance, ISO and Image Quality settings may require adjustment. Have your manual open when you do this and work through it step by step. Try the camera after each change so that you will learn which setting was at fault.
Jun 28, 2011 | Canon PowerShot A460 Digital Camera
How do i change my picture size
hi
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
  1. 1
jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.1-800X800.jpg'); }); Open Microsoft Paint. Paint is usually found under "Start," "Programs" and "Accessories."
  1. 2
jQuery(document).ready(function(){ jQuery('#jsArticleStep2 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.2-800X800.jpg'); }); Click on the "Image" menu, and choose "Attributes." This will open the "Attributes" box.
  1. 3
jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.3-800X800.jpg'); }); Choose which "Units" you would like to resize your image in. The options are "Inches, "Centimeters" and "Pixels."
  1. 4
jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.4-800X800.jpg'); }); Enter the "Width" you would like the image to be.
  1. 5
jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.5-800X800.jpg'); }); Enter the "Height" you would like the image to be.
  1. 6
jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/a04/qo/52/change-image-size-paint-1.6-800X800.jpg'); }); Click "OK." Your image should now be the appropriate size.
Aug 14, 2010 | Lexmark X2500 All-In-One Printer
I have a nikon d40 that works great ewxcept for one day i was taking pictures and all of a sudden the camera would not take a picture in auto or manual and theres a warning sign flashing "r11" where the...
Slow down your shooting. The "R11" indicates that you can take 11 more images before the buffer is full and the camera will stop functioning until the images are moved to the memory card.
Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longerTurn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Step 3 Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longer.
  • Step 4 Turn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Read more: How to Fix the R11 Error on a Nikon D40x Digital Camera | eHow.com http://www.ehow.com/how_6327343_fix-nikon-d40x-digital-camera.html#ixzz0wC3WxqrT
    Aug 10, 2010 | Nikon D40x Digital Camera
    How to use the overlay function. is similar to a multiple exposure?
    MULTIPLE EXPOSURE AND IMAGE OVERLAY......
    These are two separate functions that give control in-camera that normally is only available in-computer. The Multiple Exposure system allows one to create a single image from up to 10 separate exposures, while controlling the division of exposure needed for an accurate final image.
    The Image Overlay function allows one to create a composite image by combining two separate images in camera, and varying the opacity of the two images. The final results are saved as a stand alone image, and the original files are saved also. This could be used instead of a neutral density filter, by shooting for the dark to mid tones in one image, and the mid to high tones in the other, then combining the two images, in-camera, for one properly exposed image with much a wider light range.
    Hope this has helped you...
    Please rate the answer...
    Thanks..
    Jun 30, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
    I want ot enlarge a drawing of a leaf - how do I do that?
    If you're trying to do this without a computer, just printing an image directly from a camera or memory card in a printer with that function, enlarging is often available through the menu functions. The actual process would be explained in the user guide. (I'm not assuming you have the Kodak printer listed.)
    You can also load the image into a computer and enlarge it. How would depend on what program you use to process the image. I use a program called IrfanView. It's meant mainly for image viewing but has a good selection of processing tools as well. It's very easy to resize images with this program. It's also free without any restrictions, nag screens or associated adware.
    In general, just load your leaf image into whichever program you're using, then use the program's "help" screens to find its "resizing image" process.
    Feb 24, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
    LCD monitor works to display picture already taken and the menu display, but with not display live images. Must use the view finder. Menu does not have a "live view"
    There is no function to do this on the EOS 400D. Don't forget the camera is an SLR and still has to open and close a shutter to take a picture. The image is then converted using a CCD instead of exposed on film. I find with my 20D I just take loads of pictures and review them and then delete the ones that I don't want. This is the beauty of the digital age.
    Jan 17, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
    Nikon D70s Digital Camera Logo
    47 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Ric Donato
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
