Sony STR-DG510 Receiver Logo
Posted on May 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No audio output to speakers from optical BD input
I have been using an STR DGS520 for some time, with a PS2 as my Blu-ray player, with an optical cable to the receiver. After a home power failure while the system was running, I have no sound output to the speakers. The sound is still being received by my monitor, and I canm listen through that, so the problem is not with the cable or set-up. The display on the front of the receiver says that it is set for optical input.
I would appreciate any suggestions.
dj_relly999
Level 2:
President:
  • Expert 4,070 Answers
  • Posted on May 30, 2010
dj_relly999
Expert
Level 2:
President:
Answers
4070
Questions
0
Helped
1065039
Points
206
Hi! The capacitor that links to the audio output may have blown during the power failure causing it not to work. Try checking the capacitors for this may need replacement. This can be found inside the unit attached to the mainboard. Hope this helps and good luck!
How do I connect my DISH, TV and Blu-ray. Right now I have my DISH satelite HD cable connected to the TV, and a HD cable connected from my TV to the Blu-Ray. The problem i'm having is the sorround sound...
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
ok
I cannot get blu ray speakers to pay over normal
you can if your tv has phono outputs plug phono plugs in phono outputs on tv at one end then plug other end in to audio phono input on blue ray player
1helpful
Reciever overloads/recently installed blu-ray player
Overloads are generally heat- or current-related. Digital inputs don't have adjustments (all 1's is as high as they go), so I doubt there is any relationship between the Blu-Ray's optical cable and the overload.
You've said what doesn't affect the problem, so what's that leave? I'd look at shorts or mismatches between the amps and the speakers.
1helpful
Video but no audio
This receiver does not support audio via HDMI. You need to connect BD player via spdif cable. Use optical or coax depending on what does the BD player support - receiver supports both.
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
1helpful
2answers
COULD YOU TELL ME IF IT IS POSSIBLE TO CONNECT MY DAV-S500 SYSTEM TO A SONY BLU-RAY A BDP-S300 SO THAT I CAN USE IT FOR THE SURROUND SPEAKERS
you need to go into the settings on the bluray player and go into the audio settings and change the sound output to dts
2answers
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
2answers
Only decoding in pro-logic
go in blue ray dvd menu as dvd is playing and select the audio out formatt u wann use has to be on 6.1 or least 5.1 digital not 2.o ch ok and u may be seding the digital with the hdmi outs not both be hard for it to do doe syour tv had digital opti out run that to reivciver on digital input ok tell blue ray options menu also digital oput bitrate ok
2helpful
5answers
Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
