Question about Rain Bird Xerigation XCZ-100
Rainbird controller randomly fails with error message "bad wiring
I have an issue with my rainbird system where at random times the controller at random times says I have "bad wiring" . I think the problem is thst I am running 2 pumps on the system at the same time with 2 separate pump relay switches. The controller gives me two wire slots for the common, so I added a second common to wire to the second switch relat switch to start the additional pump. It worked for a while but the same problem happen again. Any ideas what I could do differently?
woobie dog
  • 1273 Answers
SOURCE: how do you reset the timer for a rainbird
Resetting involves reprogramming, but that's easy to do. You probably have a cheat sheet, like I do.
Unplug the timer, remove the battery, and go have a cold drink (let it sit for about 10 minutes. Reinstall the battery, plug it back in and you are good to go. Reprogram.
Regards, --W/D--
Posted on Jul 20, 2009
  • 207 Answers
SOURCE: rainbird controller lock up
You need to replace your controller.
Posted on Jul 09, 2009
woobie dog
  • 1273 Answers
SOURCE: I change the battery on sprinkler RainBird box and
When the battery is removed and the power is off, it has to be reprogrammed when power is restored, but you knew that. Check that the battery was reinstalled properly, and that the 'wall power' is hot, and properly seated to the unit. This should do it.
Best regards, --W/D--
Posted on Aug 03, 2009
protek480
  • 1714 Answers
SOURCE: I have a Rainbird ISA 300/400 sprinkler system. It
All you have to do is set the program 'A B' switch to the 'A' position. The program that you have set for A will run only. B is not active.
Posted on Sep 03, 2009
SOURCE: I have a Orbit 57161
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Posted on Oct 06, 2010
Error code 8 on Rainbird E class controller
Check with Rainbird. Could be low PS voltage, bad solenoid(s), electronics meltdown, bad timer setting, etc.
Once you know what the code means you can roll up sleeves and get to it.
Sep 03, 2017 | Computers & Internet
Rainbird esp modular controller will not operate system -
Make sure that the transformer is supplying the 26 volts ac required by the pump relay and zone solenoids. If the voltage is there and unit still will not operate then the electronics are to blame.
Jul 22, 2016 | Rainbird Rain Bird Esp-4mi Esp Modular...
Rainbird troubleshooting
Check to see if the wiring is crossed.
Jul 18, 2014 | Rainbird Rain Bird Esp-lx 4-station...
Check to see what the codes refer to. It could be a zone solenoid going bad.
Jul 13, 2014 | Garden
Try resetting by unplugging it for a minute. If that does not work, post the model of the unit.
Jul 08, 2014 | Garden
They shouldn't be working all at once. Check the wiring. Each zone should be on it's own terminal in the controller. Also check the boxes outside to see the wiring wasn't done incorrectly.
Jul 06, 2014 | Garden
It is likely the water pressure is low (perhaps a leak in the irrigation pipe) or simply the spring is stuck. Wonder if you have more than one sprinkler connected and if all are having the same problem.
Jun 13, 2014 | Garden
Rainbird sprinkler system one station sets off alarm on controller and wont run''
Ususally means you have a bad solenoid on the valve. Find the valve, disconnect solenoid and run system. If no error on controller, then that is the problem.
Jul 05, 2009 | Rainbow Garden
Rain Bird Xerigation XCZ-100 Logo
210 people viewed this question
Top Rain Bird Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Rain Bird Hardware and Accessory Expert? Answer questions, earn points and help others
