Question about Linksys WRT160N Wireless Router
Vista to Vista wireless, Can't share printer
I'm running a home private wireless network. Dell PC wired to the printer. Dell Vista PC is also wired to the Linksys Router. New Toshiba Windows 7 Laptop connects to the Dell (and printer) just fine. Other Toshiba Vista Laptop cannot connect to the Dell and printer. Any suggestions? Thanks, -Jack
  • 428 Answers
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping 192.168.1.2 (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
Posted on May 30, 2010
CAN THE DELL AIO 948 PRINTER BE USED FOR SHARING
Yes, If it is connected to a computer on your home network, right click the printer, setup sharing. For example, if you have a laptop on the same home network, Add a network printer to the laptop and print wirelessly without a wireless printer. This may help clarify: http://windows.microsoft.com/en-US/windows7/Install-a-printer-on-a-home-network OR http://windows.microsoft.com/en-US/windows-vista/Install-a-printer-on-a-home-network
Dec 31, 2012 | Dell 948 All-In-One InkJet Printer
Tip
Tips to help you work more securely from Wi-Fi hotspots in public
7 tips for working securely from wireless hotspotsWireless hotspots are changing the way people work. These wireless local area networks (LANs) provide high speed Internet connection in public locations—as well as at home—and need nothing more than a mobile PC such as a laptop or notebook computer equipped with a wireless card.
In fact, hotspots are an everyday connection method for travelers and remote workers to browse the Internet, check their e-mail, and even work on their corporate networks while away from the office.
Hotspots range from paid services, such as T-Mobile or Verizon Wireless, to public, free connections. Hot spots are everywhere, including:
  • Coffee shops
  • Restaurants
  • Libraries
  • Bookstores
  • Airports
  • Hotel lobbies
But they all have one thing in common—they are all open networks that are vulnerable to security breaches. And that means it's up to you to protect the data on your PC. In this article, we cover a few tips to make working in public locations more secure.
Try to choose more secure connectionsIt's not always possible to choose your connection type—but when you can, opt for wireless networks that require a network security key or have some other form of security, such as a certificate. The information sent over these networks is encrypted, which can help protect your computer from unauthorized access. The security features of different networks appear along with the network name as your PC discovers them.
Make sure your firewall is activatedA firewall helps protect your mobile PC by preventing unauthorized users from gaining access to your computer through the Internet or a network. It acts as a barrier that checks all incoming information, and then either blocks the information or allows it to come through. All Microsoft Windows operating systems come with a firewall, and you can make sure it's turned on.
To activate the Windows Vista Firewall
  1. Click Start and then click Control Panel.
  2. In Control Panel, click Network and Internet.
  3. Under Windows Firewall, click Turn Windows Firewall on or off.
  4. Ensure that On is selected.
To activate the Windows XP Firewall
  1. Click Start, and then click Control Panel.
  2. In Control Panel, click Network Connections.
  3. In the Network Connections window, under Network Tasks, click Change Windows Firewall Settings.
  4. In the Windows Firewall dialog box, on the General tab, ensure that On is selected.
Monitor your access pointsChances are that there are multiple wireless networks anywhere you're trying to connect. These connections are all access points, because they link into the wired system that gives you Internet access. So how do you make sure you're connecting to the right one? Simple—by configuring your PC to let you approve access points before you connect.
Configure Windows Vista Access Points Windows Vista takes the guesswork out of connecting to hotspots because you are automatically prompted to approve new connections. In addition, after you approve a connection, you assign it a profile for future use.
Configure Windows XP Access Points
  1. Click Start, click Control Panel, and then click Network Connections.
  2. Right-click Wireless Network Connection, and then click Properties.
  3. On the Wireless Networks tab, make sure that the Use Windows to configure my wireless network settings check box is selected.
  4. Under Preferred networks, make sure that the name of the network that you want to connect to is highlighted, and then click Advanced.
  5. Click Access point (infrastructure) network only, and then click Close.
Disable file and printer sharingFile and printer sharing is a feature that enables other computers on a network to access resources on your computer. When you are using your mobile PC in a hotspot, it's best to disable file and printer sharing—when it's enabled, it leaves your computer vulnerable to hackers. Remember, though, to turn this feature back on when you return to the office.
Disable file and printer sharing in Windows Vista
  2. Click Network and Internet, and then click Network and Sharing Center.
  3. Under Sharing and Discovery, click the arrow next to File sharing, click Turn off file sharing, and then click Apply.
  4. Click the arrow next to Printer sharing, click Turn off printer sharing, and then click Apply.
Disable file and printer sharing in Windows XP
  2. Click Security Center, and then click Windows Firewall.
  3. Click the Exceptions tab, and then under Programs and Services, clear the File and Printer Sharing check box.
Make your folders privateWhen the folders on your mobile PC are private, it's more difficult for hackers to access your files.
To make a folder private in Windows Vista Windows Vista not only makes folders private by default, but it also requires passwords for shared folders. As a result, you're already covered! But if you want to double-check, simply right-click on the folder in question, and select Properties. On the Security tab, you can review the set permissions.
To make a folder private in Windows XP
  1. Click Start, and then click My Computer.
  2. Click the drive where Windows is installed, and then click Documents and Settings.
  3. Open your user folder, right-click the folder that you want to make private, and then click Properties.
  4. On the Sharing tab, click Do no share this folder, and then click OK.
Repeat the steps above for each folder that you want to make private.
Encrypt your filesYou can protect your files further by encrypting them, which requires a password to open or modify them. Because you must perform this procedure on one file at a time, consider password-protecting only the files that you plan to use while working in a public place.
Consider completely removing sensitive data from your notebook PCIf you're working with extremely sensitive data, it might be worth taking it off your notebook PC altogether. Instead, save it on a corporate network share and access it only when necessary. This way, you have multiple safeguards in place.
A few simple precautions can help make working in public places more secure. And by selecting the best connections and adjusting settings, you can enjoy productive and safe work sessions no matter where you are.
on Dec 28, 2009 | Computers & Internet
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Dell 3300 Printer Adapter and Vista
Vista is tricky when adding networked printers.
Add printer by using a local device, not a networked device.  Assume the printer is connected locally to the machine.
Feb 01, 2009 | Dell Inspiron E1705 Notebook
Printer won't print
You have to turn printer sharing on in vista by going to your network map and turn the printer sharing on. This should FixYa! Network Map is located in Network and Sharing Center on the computer with vista.
Jan 27, 2009 | Dell Inspiron 6400 Notebook
Just purchased laptop with windows vista home premium
If your PC has a wireless card, you can setup an AD-HOC network :
If your PC is XP: http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
If your PC is Vista: http://windowshelp.microsoft.com/windows/en-us/help/293c504f-b944-4d5d-835c-f080129bd5dc1033.mspx
If your PC only has a wired Ethernet connection, you may still connect the two using a Wireless Access Point/Router.
Once you have the two computers connected, you may do whatever networked operations you would like:
File & Printer Sharing is the most common:
XP: http://www.wellesley.edu/Computing/FileSharing/Windows/win2kxp.html
Vista: http://www.windowsnetworking.com/articles_tutorials/File-Print-Sharing-Windows-Vista.html
Aug 01, 2008 | Apple iPhone 3G
Unable to share printer
You need to go into the machine that manages the printer and allow the access denied machine access or to share printer. You may have to run the network setup wizard in order for the machines to recognize each other.
Jun 23, 2008 | Dell Inspiron 1501 Notebook
Setting up a new computer on a wireless network
hello Danj29,
I suggest you make sure that your Vista is configured to connect to a private network. To do this follow these steps:
1. Click Start, right-click Network, click Properties.
-The Network Sharing Center window displays the network type in parenthesis after the network name.
2. To the right of the network name and type click Customize.
3. In the Set Network Location dialog box, click Private, and then click Next.
4. In the Successfully set network settings dialog box, click Close
By changing your network location type to private, network discovery is automatically enabled in the Sharing and Discovery section of the Network and Sharing Center window. The following additional file and printer sharing options must be manually enabled:
  • File sharing
  • Public folder sharing
  • Printer sharing
  • Password protected sharing
When all of these sharing and discovery options are enabled, your computer can:
  • Locate other computers and devices on your home network and have other computers locate your computer
  • Share its folders
  • Share its Public folder
  • Share its printers
  • Require user names and passwords for other computers that connect to the shared folders and printers of this computer
To enable file sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to File sharing.
  2. Within the File sharing settings, click Turn on file sharing, and then click Apply.
To enable public folder sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Public folder sharing.
  2. Within the Public folder sharing settings, click one of the following:
    • If you want to share the public folder so that other computers on the network can access the Public share to open files, but not create or change files, click Turn on sharing so anyone with network access can open files. This is the default setting.
    • If you want to share the public folder so that other computers on the network can access the Public share to open files and also create or change files, click Turn on sharing so anyone with network access can open, change, and create files.
  3. Click Apply.
To enable printer sharing and share all of your connected printers, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Printer sharing.
  2. Within the Printer sharing settings, click Turn on printer sharing, and then click Apply.
[Optional] To enable password protected sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Password protected sharing.
  2. Within the Password protected sharing settings, click Turn on password protected sharing, and then click Apply.
Hope you find this helpful info and thanks for using the FixYa service
Kind regards
Feb 14, 2008 | Computers & Internet
Can't see other PC's on my network with Microsoft Vista basic
set up file sharing and make sure the laptop is set to "private" not "public" in the Networking and Sharing Center.
Nov 20, 2007 | Microsoft Windows Vista Ultimate Edition
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Linksys WRT160N Wireless Router  Logo
115 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
