Question about Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
How to switch jumper from 220 to 110 v on hayward max flo II pump and to which terminals do i connect the wire from the power cord?
john224
  • 1378 Answers
SOURCE: Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Posted on Jun 14, 2009
john224
  • 1378 Answers
SOURCE: I am installing a Hayward Pool pump max flo II at
Either one. Neutral to the other post. Be sure to set the voltage change device to 115V to match your incoming line voltage.
Posted on Sep 15, 2009
Testimonial: "That's outstanding info for anyone installing a pool pump. Tom Smith"
  • 990 Answers
SOURCE: I have a Hayward Max-Flo II pool pump and it is
Sounds like the bearings but uou would need to take it to a motor shop to have this done. This will cost less than the spectility tools needed to do the work.
Posted on Mar 29, 2010
  • 64 Answers
The bearings have likely lost their lubrication and have failed. You may be able tot find a local electric motor repair shop to replace the bearings. It really is not a diy project. However, if you can't find a local shop to do it, most folks replace the motor.
Posted on May 29, 2010
  • 990 Answers
SOURCE: 2nd Hayward Max Flo 2 hp pool pump stopped working again!!!
More than the motor it is probally a bad seal causing the problem with the motor. All you can do is be sure it is installed right when you put the new one in and if you see water under the pump take it apart and install a new one. I live in AZ and the water will evaporate before it gets to the ground under the pump so here this can be a real annoying problem. We quite often will have to look for calcium left behind when something leaks.
Posted on Jun 27, 2010
Wiring diagram
see side of motor for wiring
May 29, 2013 | Hayward Pool & Spa
Electrical cord hookup switch 230 to 115 hayward
When you take the plate off of the side of the motor, there's a diagram there that shows you how to hook it up to 220 or 110
Aug 02, 2012 | Hayward Max Flo II Pumps MaxFlo II Single...
How to install a power cord to a Hayward 1hp Power Flo Matrix pump.
One line lead wire to the L1 terminal, the other line lead wire to the L2 terminal and the green ground wire to the green grounded screw above the motor terminal board. It does not matter which wire, white or black, is on which terminal, L1 or L2, so long as one wire is on each terminal.
John
May 24, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
I have a Hayward max-flo ii pool pump and it is very noisy. I already replaced all seals because it was also leaking. Are the bearings the cause of the noise? If so how do I replace bearings?
May 15, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Max-flo II pump leaking at top (discharge) fitting. Removed and re-taped but still leaks? Can pipe dope be used, would that be better?
Tape usually works better. Permatex sells a product that works well. If you put ten (10) turns of tape you should be okay
May 12, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
I am installing a Hayward Pool pump max flo II at 120 volt. I have 2 connections L1 and L2. Which one does the black hot wire go to.
Sep 15, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Hayward Power Flo Lx 1 Hp Pool Pump Sp1580 Logo
173 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
