Question about Whirlpool GEW9878LW Electric Dryer
Whirlpool AWZ 3703 has stopped heating, what should I look for?
  • 5,911 Answers
If your dryer runs, but does NOT heat, the following two links explain how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
http://www.fixya.com/support/r3574266-thorough_dryer_advice
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need. The heating components are usually listed under the "Bulkhead" section.
NOTE: In many cases the problem is not the heating element. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back and let me know. I hope you find this information is helpful.
NOTE: The model number you provided does not cross reference to anything. Either you listed it incorrectly, or did not provide a COMPLETE model number. On Whirlpool dryers, the number can be located on a nameplate along the door opening.
If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.
Repairclinic.com has a repair manual that you can purchase that will also help repair any Whirlpool manufactured gas or electric dryer. The part number is 1159257.
Posted on May 30, 2010
Whirlpool AWZ 8578 - does not stop, always needs manual switch off
These symptoms most usually are a bad timer/control. If the dial turns all by itself, and continues to turn by itself like a clock does, it is likely a timer/control must be replaced. Same results if it will not advance by itself either.
You could type in "Sears Parts" for the new part, typing in your complete model number. If you wished to try a used control, after obtaining a part number, you could type that in to "e-bay" and see what you find in new or used parts there. I do.
Be blessed.
Feb 15, 2014 | Whirlpool Dryers
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Awz 9813 whirlpool
Check your thermal fuse, if that is ok make sure that your heating element has continuity. Also check your cord you need 240vdc at machine to operate, it will run with 120vdc but needs 240vdc to also heat.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Jul 31, 2013 | Dryers
Whirlpool awz 7303 dryer will not heat
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Whirlpool Dryers
Whirlpool AWZ-7813 won't dry - no heat
it will either be you element or the thermostats that have failed.
Mar 20, 2010 | Whirlpool Dryers
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Whirpool AWZ 480 dryer
It could be as simple as a door switch adjustment. Get it fixed under warranty.
Sep 12, 2017 | Whirlpool Dryers
Whirlpool GEW9878LW Electric Dryer Logo
370 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
