Question about Maytag MZD2766GES Side by Side Refrigerator
Both sides are warmer than should be. motor running nonstop
    President:
  • 2,468 Answers
Replace the ptc overload on the compressor,just unplug and plug in a replacement ptc,its worn out and cant start the compressor,when its out shake it by hand and if it rattles this is a good sign its bad
Posted on May 30, 2010
The drain pan is dry. There is ice buildup on the top half of the defroster. The compressor runs nonstop. The temp doesn't get any cooler than 45. The condenser is clean enough to see through and the door...
Is the evaporator fan motor running? If it is only running at half speed or not at all, that could explain the ice buildup. If the coils are icing up because of no air flow over them, then the defrost heater stays on, trying to get rid of the ice.
Sep 14, 2013 | True T-49 Side by Side Refrigerator...
Radiator fan running nonstop
Hi Bro, Have you check one single wire to switch temperature, if this unplugged the fan will run nonstop, even without your engine start and your key is in "ON" position, it's exactly what happen to my 1994 corolla
Mar 20, 2013 | 1990 Toyota Corolla
Motor keeps running and filtering nonstop
Check your temp probe, if it is overheating it thinks it needs to run the heater and the pump.
Aug 25, 2012 | Garden
Refrigerator not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 03, 2010 | Amana ARS266ZBS Side by Side Refrigerator
You refrigerator needs regassing that is why things are not cooling. Your sides of fridge are hot because the motor keeps running to keep what gas is there flowing though the lines trying to cool fridge
May 25, 2010 | Maytag MZD2766GES Side by Side...
Freezer motor running nonstop
Behind the back panel you will find the freezer fan motor. unplug and take everything out. take the back panel off and find the fan. stick something in the blade like a bannana or whatever (no rags or paper towels though) just something to jam the blade (its plastic so dont break it) replug. remove whatever you put to jam the blade and if you hear the sound then you know for sure it is the fan. got to replace fan if you want the noise to stop
if it is not the fan let me know
hope this helped
Apr 01, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
Our maytag refrigerator runs nonstop and doesn't get as cool, even after cleaning coils
Chek the interior lights. Make sure they are turning off. One bulb will cause these symptoms. Is the bondensor coil hot( it's the coil under the unit. If it is, The fridge is working but has a heat source that won't quit or run out.
Nov 17, 2009 | Maytag MZD2766GES Side by Side...
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore Model 363 makes Clunking sound
sounds like the mount may b loose.(motor mount)
If so you may want to get under the machine and check to see if there are some screws missing or lost. (they may b on the floor rite next to the motor;)
good luck;)
Feb 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
