Question about Water Banzai Color Stream Blaster Gun
How do i fill my colorstream water blaster with water
I have a Toshiab 57H82 HDTV and when I connect my playstation 3 to the colorstream HD 2 input the colors are primarily green. In colorstream HD 1 the ccolors are fine, but its becoming a hassle having to...
If you have the wires switched GEEN,BLUE,RED on one end the color will be wrong. Check that the color off the wires are matched. Try a new cable. I've seen this a lot.
Nov 28, 2009 | Toshiba 57H82 57" Rear Projection...
I am using ColorStream for my HD inputs, the top and bottom of every HD input is cropped. how do i adjust in colorstream mode?
There should be a wide/screen size/ format button on the TV remote that allows you to make those adjustments.
Nov 11, 2009 | Toshiba 57H81 57" Rear Projection...
Sand Blaster: air shot out of water trap.
1. do you have an adequate air compressor, meaning can deliver sufficient air supply to the sand blaster. 2. if you have an air leak at the water trap at the bottom of the trap it self. you need a new one. 3. it is a must to have a water trap when using a sand blaster.
So what I would do is replace the water trap and install the new water trap at the compressor between the compressor and the air hose coupling. the reason for this is your less likely to have it fail at the compressor VS at the sand blaster. once you have done that. you need to make sure that you have no more than 3/4 of media / sand in the sand blaster itself.
then open air supply valve #1 where the water trap is or was a 1/4 -1/2 way. then open the mid way valve#2 1/4 - 3/4 way. and the bottom valve#3 open 1/4 - 3/4 way. getting the air supply valves all set correctly is hard to do some times.
Air valve #1 supplys the air to the blaster.( more air the better)
Air valve #2 supplys the air going into the top of the blaster tank. ( wich pressurizes the top of the tank to push the sand or media downward )
Air valve #3 supplys the air mixture to sand at the bottom of the tank.
Mar 20, 2017 | Clarke Power Products Clarke SB9008 10...
For saeco magic comfort plus, I can't purge it! the purge indication is always on even if i use the water, steem etc. what can i do ?
in the kit of the machine they give a little pump if you dont have it use a turkey blaster the toll when you cook a turkey to put juice on it use that remove the water tank fill the blaster with water open side valve put pressure on the blaster put it in the hole where the water tank goes and apply as mush pressure as you can repeat it should vent itself if sign goes off refill water tank that it pierre
Dec 21, 2008 | Saeco Magic Comfort Plus Espresso Machine
New gaggia baby class "d" espresso mch
it seem the pump is not prying itself you have to inject water try with a turkey blaster the pump to put juice on a turkey fill it up with water start the machine inject the water in the water hole try that out let hope it work if not you have warranty good lock
thanks for using fixya
pierre
Feb 28, 2008 | Gaggia Baby Espresso Machine
Ventilate
you didnt use the machine for a long time start the machine remove the water container if you have a turker blaster fill with water the hole were the water container goes put the blaster in it and apply pressure and try to ventilate and for descaling the machine use descaler not vinergar. vinegar remove calcium in little piece descaler melt it use 1 part descaling produit 1 part water put that in water container start machine open valve turn it off after a few second let it rest for 15 minute and repeat untill empty do 2 or 3 rinse cycle with clean water it important that stuff is corosif thanks for using fixya pierre
Feb 10, 2008 | Saeco Vienna Espresso Machine
Titanium plus stuck on rinsing cyle
go in the menu remove rince cycle after it say ventilate put water in container start machine open valve it should ventilate if it doesnt remove water container take turkey blaster put water in it put the blaster in the hole were the water container goes force pressure with the blaster at the same time open valve you vented by now put cointainer back fill with water enjoy thanks for using fixya pierre
Feb 10, 2008 | Gaggia Titanium Espresso Machine
Creative modem D15663
pls I need a driver for creative modem blaster D15663,pls help me
Sep 23, 2006 | Creative Labs Blaster V.92 Modem
Water Banzai Color Stream Blaster  Gun Logo
20 people viewed this question
Top Water Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Water Toy Expert? Answer questions, earn points and help others
