Question about Microsoft Xbox 360 Console
My image gets black for less then a sec from time to time..at iregular intervals any ideea ?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
It is in a game
kindly observe if it happening online and offline game
Posted on Jun 07, 2010
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Cof 32 reset minolta dialta toner
C0F32
Faulty ATDC Sensor
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is less than 5% (greater than 4.63 V).
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is 19% or more (1.41 V or less).
Feb 05, 2014 | Minolta DI2510 Black and White Copier
How do i fix the screen on the my touch 4g it turns black when making a call even when it is not up to my ear and it wont go back after the call is over
What is your screen time-out set at?
1. go to Apps
2. Goto Settings
3. Goto Display
4.Goto Screen time and find out what time interval is checked. The less time the less battery consumption.
After the call is made, press the on/off button. The screen should lightup.
Oct 19, 2011 | HTC EVO 4G Smartphone
Really Grainy low quality pictures with my new camera.
Try shooting with ISO value of 200 or less; or set to "Auto".
If you're missing the manual, you can get it in English, here. Page 76 briefly discusses ISO settings. This camera can select an ISO as high as 1600. ISO has to do with graininess of film - the higher the number - the more grainy the images. Higher ISOs are selected when light levels are low and no flash is used or is usable (such as when the subject is too distant). Some photographers use higher ISO settings with high shutter speeds to stop fast moving objects (like wheels on a race car). The grainier the film, the quicker it captures light. Fime grained film takes longer to capture light.
Generally, pictures taken outdoors in sunshine look best when ISO is 100 or less. 100 is a good choice for well lit indoor pictures, too; but may be better with an ISO of 200. ISO works like this:
If a picture can be properly exposed with an ISO of 100 in 1/15 sec, it would require only 1/30 sec at ISO 200, or 1/60 sec at ISO 400. When you double the ISO value, the exposure times are halved. What's the big deal about 1/15sec, 1/30 or 1/60 sec you might ask? Easy! the picture will probably be blurry at 1/15 and even 1/30 sec exposure time, due to the camera recording even the slightest movement of your hands. You'll need to supply a tripod or do something else (such as increase the size of the opening of the aperture or f-stop) to get a properly exposed image.
I hope this helped - if it isn't an ISO problem - let me know. Good luck!
Dec 10, 2010 | Canon PowerShot SX30 IS Digital Camera
The pictures are all black and possibly have a stuck shutter.
Try shooting on slower speeds such as 1/30 sec and less and see if you can see some images.
If all the pictures are black on 1/125 and faster speeds, you will need to have the shutter curtains adjusted.
May 10, 2010 | Photography
Steady red status light on NEC VT45 projector. Would not POWER ON. LAMP was replaced with a new one
the power supply on that model seem to go bad after a while. the caps aren't properly reted it's power needs. they dry up. if you are good at soldering, replace c1 on the board (big cap) with a cap that has a slightly higher voltage rating. or replace the whole power supply. you might not be able to get one from nec, but you can try www.projectordoctor.com
Dec 16, 2009 | NEC MultiSync VT45 Multimedia Projector
Lens Error and Proper switching on Problem
Same problem for me. Try below one. Its working!!!
Press the power-on button, and at the same time Press and hold the shutter button down
Mar 11, 2009 | Cameras
F1703 17" Keeps blinking each 4sec, but I can see the PC scrren
it is a stupid moniter I have ever seen...I have 4 monitors with same problem...given many times for repair...no use...
Sep 07, 2008 | HP Pavilion F1703 17" LCD Monitor
Can I save images I record using an uncompressed (TIFF) format?
Yes. When displayed, an uncompressed (TIFF) digital image is clearer and higher quality than a compressed (JPEG) image. You should remember, however, that it takes longer to save an uncompressed image, which means that the recording interval between images is longer. Recording Interval with JPEG Format (Compressed):?2 seconds (3072 x 2304, Normal) Recording Interval with TIFF Format (Uncompressed):?65 seconds (3072 x 2304, TIFF) • In the TIFF Mode, you cannot record until the save operation of the previous shot is complete. • The above times are based on save operations using a Panasonic 64MB SD memory card. • The above times are approximate and for reference only. They are not guaranteed. • The actual time required to store images depends on shooting conditions and the memory card you are using.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Microsoft Xbox 360 Console Logo
15 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
