How much space does there need to be between the stove and the surrounding wallls?
  • Heating & Co... Master
  • 2,461 Answers
Google the make and model of your stove down load manual it will all be in there
Posted on Jun 01, 2010
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
New Valor Petrus electric top of fire, plus granite surround plus fire surround mantle get very hot, room does not. 's this a fault
If it doesn't have a blower, you may need to install a blower kit. It sounds like you need some air circulation in the room.
Jan 08, 2015 | Home
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
Cant get spring back on head light
Is this the spring that holds the reflector in to the chrome surround? if there are more than one they must be spaced equally around the surround otherwise it will push the reflector too far in one direction. Take them all off & refit VERY evenly spaced fitting diagonally opposite ones first.
Feb 13, 2011 | 2005 Honda VTX 1300 R
I have a Whirlpool GS773LXSS gas range. You press bake, it clicks once and doesn't heat up at all. Press Broil, clicks twice and doesn't heat up.
Is the gas turned on to the stove? Is the pilot light lit?
Any special circumstances surrounding this incident? like this stove is new or old. Or you are new to gas stoves etc.
Apr 09, 2010 | Tecnik TKC195/3 Electric Single Oven
Large right front glass burner snd surrounding
The item number for this through repair clinic.com is 770583 with a cost of 374.00 Most costly part of the stove. Sorry wish it could have been better news.
Mar 09, 2010 | Kenmore Kitchen Ranges
Micro wave has come loose from hanger on bottom. Need to know how to reattach microwave to brackets. maytag mmv5100
MOST OF THEM YOU CAN TAKE THE SCREWS LOOSE FROMTHE TOP OF THE CABINET OVER THE STOVE, YOU NEED TO PPL, REMOVE TOP SCREWS HOLD IT AN TILT IT AN THEN PULL IT AWAY FROM THE WALL, MOST WALLL BRACKETS HAVE A HOOK THAT THE MICRO MOUNTS TOO IT 90%OF THE WEIGHT IS BEEN HELD BY THE WALL. GOOD LUCK LEAVE SOME FEEDBACK.!
May 28, 2009 | Maytag MMV5100A Microwave Oven
Exhuast smell(odor)
J,
If your Laser 56 is giving off fumes it is probably coming from the igniter gasket and the igniter guide gasket. The igniter gasket has broken and needs to be replaced with the new style. The new style cost about $12. The guide gasket is the fiber gasket around the hole the igniter goes in. It has seperated and all you have to do is smash it back together. If you have high temp silicone or furnace cement, you can use either to seal the crack. Any toyotomi dealer can get you the new igniter gasket # 17185580.
Good luck,
Tom Hawkins
hawkins111@gci.net
Feb 28, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Paint had gone on surrounding the clock area
You can get spray paint in stores. Here is the kicker. Generally speaking Ovens and stoves have a baked on finnish. The problem is going to be getting a (And this is the key words) "High Heat" paint that matches the color of your stove. Most paint stores have "High Heat" in black red or silver to paint Bar B Q's with. However most do not have a multitude of colors that kitchen appliances come in. If your stove is one of those colors then problem solved go to the local paint store and pick it up. If not try looking at automotive paint stores for the similar color. In an automotive store you will look in the isle for Engine paint. If you can not find a paint that matches the color in High Heat, you could try an appliance epoxy. The thing is that is usually used on refridgerators, washers, dryers etc and not recomended for stoves. Try a small spot and monitor it. If it begins to peel my recomendation would be replace the stove as coatings beyond that will start to become more pricey than a new range.
Aug 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
I want to use cement board behind the wood stove. Do I need an air space?
I talked to the firechief , no I do not need a air space.
Jun 23, 2008 | Kitchen Ranges
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
