Question about Kenmore Dryers
Dryer wont get hot - Kenmore Dryers
  • Kenmore Master
  • 8,220 Answers
It could be the heating element, a safety limit, a control problem, or an electrical problem. A heating coil is used to warm the clothes as they get tossed gently inside the drum. A blower mounted on the motor pulls air through the heating element into the drum and out the exhaust.dryer wont get hot - 71b523c.jpg The element gets old and briitle with use and eventually needs replacement. That is what you check first. 0d21cec.jpgOn gas dryers vibration and age will cause the igniter to crumble and fail. If it turns out the element is fine then one of the safety's might be blown. These safety's are set to a certain temperature
for the dryer to operate safely. The drum temp control for cotton is 160f. 089a5d8.jpgA limit on the heater housing is 250f. If it fails another smaller limit is mounted nearby that blows at 300f. If that temp exceeds 350f a duct fuse mounted on the blower housing opens and kills most dryers.dryer wont get hot - f6fe985.jpghttp://i.fixya.net/uploads/images/f6fe985.jpg" alt="f6fe985.jpg" class="h_mi" />On gas dryers the duct fuse will kill the gas assembly but the dryer will still run. If all of those safetys are good the timer dryer wont get hot - 4f2431c.jpge problem. 4f2431c.jpgThe timer has a terminal on it that runs down to the heating element. If you suspect it is bad you can check it with a meter. That leg of the timer should have continuity with other terminals on the timer at different spots on the timer. Turning the timer and checking for continuity will give a clue. If you cannot get continuity with any other terminal on the timer at any position on the dial then you have a burned contact in the timer. If that turns out to be good, you would need to inspect the electridryer wont get hot - 7673e13.jpgfor proper power to the machine.7673e13.jpg On American models the motor runs on 120 volts but the heating element must have 240 volts. If you have more questions just post a comment. Good luck on repairing your machine.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 30, 2010
  • Dan Webster
    Dan Webster May 30, 2010
    If the element is good but the dryer won't heat and you have 220 to the dryer terminals then the high limit (1) is most likely blown. More here
We have a Kenmore 400 dryer. It gets warm but will not get hot--it is only one year old --what should we check for?
there are 2 thin coil wires that have current flowing threw it. it gets red hot and provides the heat to dry clothing, if one of these wires brake your dryer wont get so hot. very common its made cheaper all the time so it wont last.
Sep 24, 2010 | Kenmore 62622 Electric Dryer
Dryer wont get hot ?
my dryer runs and everything but wont get hot
Jul 23, 2010 | GE Profile Harmony DPGT750EC Electric...
Hotpoint dryer wont get hot
This condition is normally cause by a faulty thermostat...
Sep 22, 2009 | Hotpoint NWXR473EV Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Wont blow hot air
heating element failure 30 bucks and an hour of labor
Jan 14, 2009 | Dryers
Gas dryer wont get hot
The first thing to check is the thermal fuse. It is located in the back of the dryer, and you need to remove the back panel to get to it, which involves taking out about a dozen screws. To check it, unplug the dryer, pull the wires off the thermal fuse, connect them to each other with an alligator clip lead, plug the dryer in and see if the dryer gets hot.
Jan 11, 2009 | Kenmore 63942 Dryer
Wont blow hot air
check that you have 240 volts to the dryer terminal block
if so check the element and the element thermastats
May 07, 2008 | Estate EED4300SQ Dryer
Dryers Logo
89 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
